Engine Breaking Up
Hello all. I am a newby to these forums. I have a questions regarding my 914 race car. For quite some time the engine has been cutting out between 6000 and 7000 rpms (usually around 6300). Usually I can drive through the breaking up eventually, but often it is not worth it because I limit my shifts to 7000 rpms. The car is running a MSD igntion. At my last race at Road America (the Elkhart Lake Vintage Festival) the car started a habit of backfiring once I hit the 6000-7000rpm range. I do not know what to do nor do i know what the problem is and before I bring it in to my mechanic I would like to get some insight.
I have been told that installing a crankfire ignition such as the electromotive unit would solve my problems, in addition to giving me added performance, but before I spend all that money I was wondering if there is anything else I go look into before spending $1000-$1500. I am running a 2.0l engine with weber carbs. Any help would be appreciated. |
is it a 2.0 six or 2.0 four? I really don't know much about that problem but what comes to mind is distributor play.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
My wild ass guess is that you are running the MSD rev limiter and that points bounce and/or distributor play is getting it to trigger early. I checked in my BMW by removing the MSD's rev limiting pill and seeing if the car revved properly. Which it sort of did (points etc = bad ![]()
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
I've driven it with the "pill" in and out and it doesn't seem to make a difference. By the way, the engine is a six cylinder.
Vintage 914 Racer,
My 911 was doing the same thing. It was my Dizzy. I had enough play in the dizzy to wear it was effecting the points gap and the timing. I had it rebuilt and the problem solved. 8K all day long. Not that I shift it there but in times of need, it will go without hesitation. It only cost me $65.00 to have it rebuilt. Well worth it.
Mark Scott Vintage 911 Racer 1967 911S 2.4L ROCKET Powered by Faragallah! www.scottassociatesracing.com |
Thread Tools | |
Rate This Thread | |
