Hey guys, on my 75 Carrera, if I lift the indicator arm to take a right turn the green indicator blinks (on the dash) and I hear the familiar tick...
However when I pull it down to indicate left, the green indicator doesn't come on, and I dont hear the ticking... BUT the indicators do blink... Anyone any thoughts?
75 Carrera. Mello Yellow. |
try replacing your blinker relay.
I like them I drive them |
A possible "soution"?
Item Description Image Price
-High Quality Synthetic Blinker Fluid- Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, blinker fluid should be changed every 150,000 blinks! KaleCo high quality synthetic blinker fluid meets the highest D.O.T. standards! KaleCo blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause! KaleCo blinker fluid will not lose its viscosity, even in the most extreme situations! Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car. |
Autodidactic user
The best advice I can give is to check and clean all your grounds. Especially the one's behind the parking/turnsignal enclosures, (rain, dirt and other road trash leads to corrosion of these grounds), the transmission strap (the source of MANY electrical related problems) and the starter ground. You should also clean all the bulb socket connections and the 14 pin connector in the engine compartment. Finally, clean all the fuse connections. I think you'll see a great improvement after this. 911 electrical problems are very often ground related. Hope this helps. Changing the flasher relay (behind the oil temp gauge) with a genuine Hella unit is also good avdice. I've been having my own turn signal problems. If you want to follow along with my travails:
What would cause my flasher fuse to consistantly blow? http://forums.pelicanparts.com/show...threadid=129512 HELP!! Turn Signal and/or Flasher Problem. http://forums.pelicanparts.com/show...threadid=129246 Finally, for an easy to follow article about how turn signals work, go to the "How Stuff Works" website. http://www.howstuffworks.com/turn-signal.htm
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
I should consider myself a master on this subject...I tracked down my indicator problems, long as it took. Yes, checking and cleaning grounds and all contacts at the front and rear blinkers themselves is always a good idea. While there, coat with dielectric grease. However, I don't think this is the source of your problem.
Although it could be the flasher relay, my indicators both flashed whenever I selected left or right and ultimately a new relay fixed this...I think they just get weak with age. I'm wondering if the problem isn't in the turn signal switch itself...they have been known to cause problems. I need to listen closely to mine and see just where the 'click' originates. If the relay, then a new one should fix it. Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Hi guys,
Newbe here... I have a project car I'm working on, (72) I'm having trouble getting the blinkers to work. I cleaned the grounds but I get no light, no flash.. Oh, my question is how do I check the switch itself? Thanks Tony |
I would rather be driving
Tony, First print off a color wiring diagram from the Pelican 911 Tech pages. Next, you will need a multi-meter capable of reading voltage. turn the key on and turn on the blinkers. You will need to start working from each end. First check for 12V at the fuse box. then you will need to check under the dash behind the ignition switch. There will be two multipin plugs. The left one will have the lights from the stalk. Check for 12V here. If not, then go up behind the oil pressure/temp guage and pull the blinker relay. test for 12V going in. You should also disassemble and clean the contacts inside. If you have not found the problem then its time to remove the blinker stalk and clean all contacts. You can also check for 12V at teh terminals on the light switch on the lower dash. Don't forget to check at the hazard light switch too. Good luck tracing the wires.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Sorry if I kind of hyjacked the thread...
Hey Thanks Jamie, I appreciate it! ps. I made the colored diagrams poster sized & stuck them on the wall. They are a big help. |
Right Hand Drive
I have a similar problem, no indicators or hazard lights but cant find the relay. I have a RHD car. Does anyone know where the relay for the turn signal is on a right hand drive car? Andrew
Andrew Johnson Newcastle , Australia 1976, 911 ROW no mods previous car Mercedes 280CE 1979. Other car 2004 Peugeot 307 Wife's & Family Truckster |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks Ronin
Found it. On the drivers side, behind the clock. You can aslo access it through the front trunk, behind the right hand wheel arch. Put your hand in and reach through the trunk towards the steering wheel. Its a small black relay about 2cm x 3cm. It has 4 pins. I pulled mine out and found it to be clean and new. I gave it a firm wiggle and made sure it was seated correctly. So far the hazards and indicators work. Andrew |
