Administrator
Jack Olsen's Avatar
Installing a 'Check Engine' light on a DME car
I've just put in the cool 'No Bad Days Racing' chip in my 1972 with a 1993 3.6 in it. The chip can manually switch between a stock mapping configuration and a modified one. But the way to determine which mode you're in is that the 'check engine' light comes on when you're using the modified maps. I swear I remember there being a simple way to wire this light in on a car not originally equipped with one, but I can't find where I wrote it down.
Anyone know?
Ingo? Ryan?
Bueller?
Old 10-01-2003, 08:12 PM
Lorenfb's Avatar
Pin 22 of the 964 DME unit provides a ground to a lamp which is
connected to #15 ("run" on ignition switch). The lamp will be on
until the engine starts, given that no DTCs exist.
Good Luck
Loren
'88 3.2
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-01-2003, 08:23 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
According to Ingo’s wiring diagram (that he wired his w/) the check engine light comes off of pin 8 of the T16 connector, which is the 14 pin connector on the DME side of the harness.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 10-01-2003, 08:28 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Yeep that's all there is Ryan and Loren. Pin 22 of the DME is routed through the DME harness to pin 8 on the 14-pin connector labeled T16 under the drivers' seat. It branches off the DME harness close to the DME box.
This signal provides ground to a lamp (the other side is B+) or LED with suitable resistor in series. Radio Shack might have LED's with suitable resistor buit in and a nice mounting socket on the shelf. If you use an LED you need to watch polarity. Kathode to Pin 8 and Anode to +12V. Kathode is the dash and Anode is the triangle. The resistor is something like 600Ohm if I remember correctly.
`````LED````Resistor`````
P8 ---|<|-------|==|---- +12V
````K``A````````````````
is
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-01-2003, 10:45 PM
