Angry Engine Drop - what did I learn
Like many on the board, winter is coming so its time to drop the engine & "look forward" to all the outstanding things to fix
With help from 2 other friends, it was quite an uneventful drop until after the engine is sitting on the dolly.
The designed-for-Porsche engine stand yolk doesn't fit because of the "cross pipe" that connects the exhaust headers. When I tried to disconnect the turbo from the headers last time, we ended up torching / dremeling for hours. So we ended up mounting the engine using the universal yolk, remove the headers (which takes all 10 min ) then transfer the engine to the proper yolk again.
Moral of the story - you may want to remove the headers first prior to dropping your engine.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 10-07-2003, 06:28 AM
Friend of Warren
Just to add to your thread. For the Carrera's (84-89) the Bentley manual gives perfect step by step instructions, with pictures, for the engine drop. I followed the instructions and everything went just as outlined in the manual. Nothing was missed. While Wayne's 101 projects has an engine drop section, it is for the SC, and to be honest is virtually worthless for dropping the engine on the Carrera.
Kurt V
Old 10-07-2003, 06:36 AM
I also use Wayne's 101 project as the primary source of info, as there is no Bentley for the turbo, and modify the procedure from there.
Main difference was remove the intercooler, airfilter first from the top. And we took the tranny out then split it from the engine.
Old 10-07-2003, 06:39 AM
Hi Patrick and Kurt,
When one drops the engine, why does it seem that no one removes the heavy muffler prior to the drop? Both Wayne and other sources seem to deal with the muffler still attached.
Advantages to removing muffler first:
1. Less weight on the total engine when dropping.
2. Less chance of damaging the muffler.
Anything else to remove prior to the drop?
Old 10-07-2003, 07:37 AM
Friend of Warren
I've done a drop with and without removing the muffler. To be honest the weight of the muffler is not that big of a deal and leaving it on does not upset the balance point when dropping the engine/tranny. In addition, I really don't see how you could damage the muffler by leaving it in place. I also find it a useful handhold when manuvering the engine during dropping and lifting.
Kurt V
Old 10-07-2003, 07:40 AM
APKhaos's Avatar
Lost count of engine drops the NOVA group has done on everything from 60s to late models. We never remove the muffler pre-drop, and I can't see any value in doing it.
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 10-07-2003, 07:49 AM
On a turbo, its also even more awkard to try to detach the turbo from the muffler / header while its in the car. For the weight-savings, I'd wait till its out of the car.
Old 10-07-2003, 07:58 AM
I have a 70T. My experience was also based on Waynes SC guide. Which if my memory serves me correctly - leaves the transmission in place on the car. I don't know how anyone can get that TO bearing to let go while in the car but I really doubt it could be re-installed after the motor was put back in. My $.02 worth on lessons learned. No, I never considered NOT taking the engine out without the transmission, but I know really well, I never Will.
Ron Broman
1970 911T 2.2
2000 Boxster
2006 F-150 Lariat
Gruppe B #090
Old 10-07-2003, 08:05 AM
Ron, I'm with you...
Sounds like its more a question for Wayne - Why does 101 Project suggest to take the engine out with the tranny still in the car?
Seems that most take the tranny out with the engine and it certainly seems a lot easier to me doing it this way than trying to separate the tranny from the engine while its in the car.
Old 10-07-2003, 09:04 AM
Ron and Patrick,
Sorry to rain on your thread, but the question I asked was not the transmission, but the muffler. Everyone knows that you should remove the transmission along with the engine or vice versa, but the muffler sits out there, waiting to be dinged. It is so easy to take it off, as anyone who does Driver's Ed and drives to the tack knows.
Also, if you remove the muffler frist, the engine will clear the rear valence more easily, etc.
Sorry for the confusing question.
1983 911SC Chocolate Kiss (Smokey Quartz Metallic)
1991 VFR750F
1982 VF750S
Miata (wife's)
Audi A6 Quattro (family)
Old 10-07-2003, 09:50 AM
Friend of Warren
Andras what you say about taking the muffler off first making it easier to clear the rear valance makes absolutely no sense. The muffler sits below the engine tray and doesn't get in the way of anything during an engine drop. As for weight, what you are talking about at most is 30lbs, so it really makes no difference. Now if you like taking the muffler off first, have at it. Really nothing to get stirred up about. Now some people do drop and engine minus the tranny. I suppose if you have a lift and a jack the will extend up to the engine it is not that big of a deal. But when you are using floor jacks dropping the engine and tranny as a combo is just much easier to do. Especially when it comes time to reinstall things.
Kurt V
Old 10-07-2003, 09:57 AM
As Kurt said, I didn't see much benefit either other than some small weight savings (ok with the turbo maybe 50lbs?).
But its a PITA to take it off while it is in the car, particularly with the turbo. So, I'd rather wait till engine's out then remove it.
Old 10-07-2003, 12:09 PM
Irrationally exuberant
ChrisBennet's Avatar
Re: Engine Drop - what did I learn
I use my air grinder to grind some yoke metal away and then spray it with some grey paint. Clears the exhaust fine now and you'd never know it was modified.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-07-2003, 12:13 PM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
I've installed/removed probably 50 VW engines and never had to pull the tranny. You're just asking for trouble with the CV joint bolts (cross-threading and what not) by removing it all. I dropped my engine last month (first time for a 911) with the tranny left as is and it was truely a piece of cake. So, I definitely do not agree with the comment:
"Everyone knows that you should remove the transmission along with the engine"
My .02 worth...
Matt
'82 911SC Targa!
Old 10-07-2003, 02:18 PM
Randy Webb's Avatar
That is a LOT better than learning -- too late -- that you are not able to bench press 450 lbs.....
Old 10-07-2003, 02:34 PM
UTKarmann_Ghia, Have you ever pulled a 2.2 from a '70 911T and left the transmission in place? If so, I need to talk with you. And Andras didn't mean to break into your post, I started reading at the top and noticed the original question;" Engine drop - What did I learn". This was why I added my comment. I didn't remove my muffler either.
rbroman@cox.net
Ron Broman
1970 911T 2.2
2000 Boxster
2006 F-150 Lariat
Gruppe B #090
Old 10-07-2003, 04:19 PM
Senior Member
Superman's Avatar
You're all correct, including Andras. As he said, if you lower an SC engine, straight down, with the muffler attached, the muffler will scrape the rear valence. Usually this is avoided because the tranny-end is removed last, after tilting the engine down.
Mocha 1978 911SC. "Coco"
Old 10-07-2003, 04:25 PM
Todd Simpson's Avatar
The 2.2's are a different beast. The motor and trans can only be seperated after rotating the throwout bearing off the fork. That requires you to look with a flashlight into the teeny window on the front of the bellhousing, then reach in there with a screwdriver.
Old 10-07-2003, 05:01 PM
Friend of Warren
Well in less time than it took to discuss the best way to drop the engine I removed the valance and bumper and rolled the engine and tranny out from the car.
Kurt V
Old 10-07-2003, 05:48 PM
kurt, get some proper lighting in there or you'll get eyestrain.
206 637 4071
Old 10-07-2003, 06:31 PM
