Me like track days
Does a 3.4 @ 9.8:1 compression - made from a 3.2 - REQUIRE twin plugs? I have a 3.2 coming with rebuilt top end and am going to have the bottom end rebuilt........and need advice!
THX, Craig www.RennStore.com
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I doubt it, although i believe you'll be limited to strictly using premium as far as pump fuel's go.
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
Craig-
If you use a relatively "hot" cam, with high overlap and duration, and don't push the timing advance too far, you shouldn't have excessively high combustion chamber pressures from 9.8:1 compression, and should be able to use premium pump gas in it with single-plug ignition without risking detonation. Keeping the engine cool will help as well (big oil coolers are helpful). The original 2 liter 911S engine had 9.8:1 compression (as do the Euro Carrera 3.2s) and they run well on premium. The weak point of the 3.2 is the rod bolts. If you are going to run the engine hard, use Raceware or ARP bolts when you do the bottom end.
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Irrationally exuberant
Re: 3.4 questions
Porsche's stated compression ratios are higher than actual measured compression ratio. For example, a 3.6 has a stated compressoin ration of 11.3:1 but a true/measured ratio of 10.4:1. I don't know if Mahle uses the "Porsche method" or not. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I have done this conversion along with C2 cams and have not had any problems.
Chris Johnson 87' 3.4 Carrera 73' 911t restoration project |
I'll further the question, "Would going with twin plugs offer and advantages, ie lower octane, higher compression, smoother idle, better milage?" I may be going this route and am most likely do the twin plugging while it is apart.
Twin plugging a 3.2 runs about $2000: Andial splitter box $600, used dual distributor $250-400, twin plugging heads ~$400, extras plug wires $200?, sheet metal mods, custom chip $400-450, 2nd coil, bracket for two coils. -Chris
Still got the parts?
-Chris
