Danskman's Avatar
Porsche Crest Time to replace clutch. Suggestions?
T/o bearing started whining like a cat last night. I guess it's clutch time. I see there are a few different options to the stock Sachs setup. Anyone have the "Power" set up with the aluminum pressure plate and corresponding disc installed? Comments appreciated. Autocrossing and DE's planned for next year.
On the bright side, I guess it'll be easier to do the tensioner upgrade with the motor out.
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 10-23-2003, 02:14 PM
Bill Douglas's Avatar
The stock Sachs are good and reliable. Quizz the other guys but I think some of the power setups are a bit like an on/off switch.
Old 10-23-2003, 02:18 PM
stock works fine. light assemblies tend to make the car harder to launch without bogging a bit.
206 637 4071
Old 10-23-2003, 02:40 PM
I have a Truman aluminum flywheel plus a Sachs (I think...) aluminum clutch. I find my wife's Boxster harder to get off the line than my so-equipped '83 SC.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-23-2003, 03:23 PM
Bill Verburg's Avatar
Sachs Powerclutch is a reasonably priced upgrade. The difference of a few pounds in the 3.2 and earlier clutch/flywheel won't make a huge difference like in the 964/993s where 30# can be shaved off.
Bill Verburg
Old 10-23-2003, 03:34 PM
Eugene at Pelican Parts's Avatar
I switched to the Sachs Power clutch and hardly felt a difference in the 'grip' of it. However, the motor is quicker to rev and the Al pressure plate sure is purdy.
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 10-23-2003, 03:37 PM
ted ted is online now
likes to left foot brake.
ted's Avatar
A lighter preasure plate might expedite your heel and toe blip.
I have the Sachs Power clutch (Aluminum PP) set up works great for 230hp (my hp, might handle more too?) and less DE/AX action.
I'd be curious if the Power pack kit still has the slotted disc. Some dont and I was told the springs in the non slotted disc are 10% stiffer than factory stock? anyone?
Old 10-23-2003, 04:17 PM
