Where can you buy relay sockets (needed for H4s)
I'm installing H4's in my car and am planning on using the 80/100W bulbs. From reading past posts, I now realize that I need to install relays so I don't fry my wires.
Quick question: I see that Pelican sells the actual relays, but where can I get the sockets to plug the relays into?
Thanks...
Old 11-05-2003, 03:50 PM
DCOP's Avatar
Try this guy, he sells an H4 conversion relay kit for around 20 bucks. msucro@rennlist.com
70-911T/ RS Tribute 2.7
Old 11-05-2003, 04:19 PM
Early_S_Man's Avatar
Porsche Crest
Andy,
You can find a socket on the 12 Volt relay page at:
http://www.hosfelt.com/
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-05-2003, 04:50 PM
scottb's Avatar
The Sucro kit is great, and comes with detailed instructions. Worth the money, IMHO.
1984 Targa
Old 11-05-2003, 05:12 PM
marcesq's Avatar
Best 20 bucks I ever spent.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 11-05-2003, 06:28 PM
Friend of Warren
Another vote from a happy user of the Sucro relay kit.
Kurt V
Old 11-05-2003, 06:34 PM
RallyJon's Avatar
I used the kind that mount to the body--then the relays plug into them. They are single bases, which slide into each other so you can put as many side-by-side as you need. Sourced from Waytek Wire. I think they sell the other kind, too.
993 · 911 · STI · S4 · rally car
Old 11-05-2003, 06:50 PM
Thanks everybody. Haven't decided who I'll get the sockets from, but I certainly have choices now. Thanks again...
Andy Ring
69 911T
72 911T
Old 11-05-2003, 07:04 PM
Glasgow 911SC's Avatar
Are the 2 relays all you need to use higher powered 80/100W bulbs? I thought you would have t re-wire the lights ans possible even use a better bulb holder????
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 11-06-2003, 06:54 AM
KTL KTL is offline
Schleprock
KTL's Avatar
From what i've read, increasing the wire size (smaller gauge) is a wise thing to do when using higher wattage bulbs. That's what I did. I got my Ancor marine grade wire from Boat U.S.
Boat U.S. Marine Supplies
I will second what Rally Jon said. Waytek Inc. is a great source for electrical supplies. Relays (Bosch), terminals, sheathing, heatshrink, good crimp tools, wire, circuit breakers,............ good quality stuff. Their customer service is outstanding. Everything is individually packaged and double-checked for accuracy. Great operation in my opinion. Good online catalog and printed catalog too.
Kevin L
'86 Carrera "Larry"
Old 11-06-2003, 07:03 AM
Thanks for the info Kevin. I'm gathering together the neccessary bits (both hardware & info) to utilise bigger bulbs.
Chris
Old 11-06-2003, 07:06 AM
