Where can you buy relay sockets (needed for H4s)
I'm installing H4's in my car and am planning on using the 80/100W bulbs. From reading past posts, I now realize that I need to install relays so I don't fry my wires.
Quick question: I see that Pelican sells the actual relays, but where can I get the sockets to plug the relays into? Thanks... |
Try this guy, he sells an H4 conversion relay kit for around 20 bucks. msucro@rennlist.com
70-911T/ RS Tribute 2.7 |
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
The Sucro kit is great, and comes with detailed instructions. Worth the money, IMHO.
1984 Targa |
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Friend of Warren
Another vote from a happy user of the Sucro relay kit.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I used the kind that mount to the body--then the relays plug into them. They are single bases, which slide into each other so you can put as many side-by-side as you need. Sourced from Waytek Wire. I think they sell the other kind, too.
Thanks everybody. Haven't decided who I'll get the sockets from, but I certainly have choices now. Thanks again...
Andy Ring 69 911T 72 911T |
Are the 2 relays all you need to use higher powered 80/100W bulbs? I thought you would have t re-wire the lights ans possible even use a better bulb holder????
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Schleprock
From what i've read, increasing the wire size (smaller gauge) is a wise thing to do when using higher wattage bulbs. That's what I did. I got my Ancor marine grade wire from Boat U.S.
Boat U.S. Marine Supplies I will second what Rally Jon said. Waytek Inc. is a great source for electrical supplies. Relays (Bosch), terminals, sheathing, heatshrink, good crimp tools, wire, circuit breakers,............ good quality stuff. Their customer service is outstanding. Everything is individually packaged and double-checked for accuracy. Great operation in my opinion. Good online catalog and printed catalog too.
Kevin L '86 Carrera "Larry" |
Thanks for the info Kevin. I'm gathering together the neccessary bits (both hardware & info) to utilise bigger bulbs.
