Bill Verburg's Avatar
I love the way you hid it in the back. What did you mount it to?
I don't remember, maybe Joe can post a pic. Ingo just wire tied his to the manifold in the back(I think).
Personally I would want to get rid of that lump(power steering blockoff)
Bill Verburg
Old 11-11-2003, 01:41 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I just didn't have the patience to fab a holder for the cannister. For the air filter I fabed two brackets out of pipe squashed flat and drilled at either end. And zip tied the cannister to one of the brackets.
I don't mind the 993 Porsche factory block-of since it is hidden under the (still absent) sheet metal. It won't interfere or take up any real estate where it is located. And it is stock.
Ryan sure did a beatiful job with all the powdercoating. I was on a tighter budget and patience level myself and just wanted to get done with the swap. The price I have to pay now is that the sucker leaks from the valve covers and the pully seal. Oh well, at least I am not running out of projects.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 11-11-2003, 01:50 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Originally posted by ischmitz
BTW: Your AFM is upside down. I made the same mistake when I first put mine together for some nice pictures. Mine was rotated 90 degress.
Rotate yours exaclty 180 degrees. The connector points to the firewall. The black plastic cap points up. If you have the stock airbox it'll be obvious how to orientate it.
Ingo
I thought about this, I don't have the stock airbox and I didn't like the way it sat the other way. Does anybody see a problem running it like this?
Ingo, did you get my email about the 25x30mm sealing ring part number I need?
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 11-11-2003, 07:43 PM
The mystery of the vacuum can mount is solved
I used the stock air box and therefore kept the stock mount. It's no wonder I couldn't remember.
Thats the kind of thing that would drive me crazy. Just knowing that it was there. I'm also sure that if I left it it would eventually be in the way.
Bill Verburg
Old 11-13-2003, 04:42 PM
