How do I remove the fan?
Hi Pelicans,
Due to terrible corrossion I'd like to remove my fan and give it a good polish. Can someone tell me how to do this? Is it as easy as just to remove the nut that holds the fanbelt and then pull the fan out of the housing unit?
Thanks so far,
Old 11-19-2003, 08:03 AM
IROC's Avatar
That's how mine came out.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-19-2003, 08:07 AM
Re: How do I remove the fan?
Probably Not
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-19-2003, 08:38 AM
85Gold's Avatar
On my 85 Carrera the fan is on a keyed alternator shaft and came off in my hands when I removed the pully. I believe that some are on a tapered alt. shaft and if you will post the year and model of your engine I am sure more knowledgeable people wiil chime in on your specific application.
Peter
2005 GT3 Black SCCA Solo 2 SS
1999 M Coupe SCCA SM2
2001 Mazda Miata (Wife's Ride)
2005 F150 FX4 + Trailex
Old 11-19-2003, 08:54 AM
Thanks so far mates, it's a 930/09 engine and indeed the fan seems to be stuck. any suggestions?
Regards,
Gerko, 911sc
Old 11-19-2003, 09:55 AM
1982911sc's Avatar
You need to remove the fan housing bolt that shrouds the fan, it looks like a big metal band around the fan, next remove the nut in the middle of the fan. I had to use a big metal pipe on the end of my ratchet to break this bolt, as the engine is constantly tensioning this bolt. After this is loose you will need to carefully pull out the fan as the alternator is connected to the back of it...by wires that you will need to reconnect. That is at least how I remember it, oh and your fan belt will come off when you release the tension on the fan center bolt. Good luck!
944 TURBO!!!!
1982 911 SC Targa (loved but sold!)
2005 Cobalt SS (0-60 in 6.1!!)
2003 BMW 325i ex got in divorce
1969 912 Coupe (sold)
PCA Member
Old 11-19-2003, 10:01 AM
Student of the obvious
LeeH's Avatar
Try this:
http://www.pelicanparts.com/techarticles/911_alt_replace/911_alt_replace.htm
Lee
Old 11-19-2003, 10:05 AM
Thanks guys, the article Leeh referes to says it all.
drive safely.
Old 11-19-2003, 10:30 AM
don911's Avatar
I used a puller to remove my fan. The puller worked great.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 11-19-2003, 11:34 AM
Hi Don,
Did you do this on the car without removing the housing, and how did you put it back on?
Gerko
Old 11-19-2003, 11:51 PM
