dickster's Avatar
Unhappy how do i remove wheel locks without a key?
finally got round to preparing the car for t/bar replacement, and i got stuck at the first hurdle - removing the wheels!
my insurance co lost the keys back in january when my car got stolen, so whats the best way to deal with this? i was thinking of drilling the locks.
any ideas/experience?
also, for all you guys with BIG garages and a LIFT!!
i have to open the rear lid to clear the workbench!
Rich
'86 coupe
"there you are"
Old 11-22-2003, 11:41 AM
i use an airhammer with a pointed bit to destroy the outer lip, which allows the guts to be extracted. careful not to let the bit slip and chew the wheel! a big hammer and chisel would probably work also. WEAR EYE PROTECTION!
206 637 4071
Old 11-22-2003, 12:00 PM
dickster's Avatar
john
no air here, so would have to be hammer and chisel. is that preferable to drilling it out?
thanks, appreciated.
Rich
'86 coupe
"there you are"
Old 11-22-2003, 12:08 PM
I'm off the hook.....
Do it the way the wheel punks do it.
Vise Grips.
When that fails, they take the other 4 off, and pry the wheel off, breaking that wheel stud.
No more wheel locks for me.
No, I don't sing. Based there for too long.
Old 11-22-2003, 12:13 PM
Fuchs w h o r e
You could try to pick them. If you had a long thin tool like a straight dental pic, you could go in there and tickle the tumblers while pulling gently on the cylinder. Your smallest allen key might do the job too. Unsophisticated locks like those are fairly easy to pick. It just takes a little longer than in the movies.
Old 11-22-2003, 12:23 PM
kcope's Avatar
A ground down hack saw blade makes a nice pick or metal strapping.
Ken Copeland
70 GT6+ KC78784
70 Spit FDU84919
70 GT6+ KC81551 (Ok so I like 70s)
71 Porsche 911T
00 Chevy Pick UP
Old 11-22-2003, 12:31 PM
drilling might work, never tried it. they come off so easy with the air rig.
206 637 4071
Old 11-22-2003, 12:42 PM
dickster's Avatar
sorry, been on baby duties. thanks for the ideas. i'll try and pick first. then i'll try and get that top ring off. drilling as a last resort.
Rich
'86 coupe
"there you are"
Old 11-22-2003, 12:58 PM
They make a tool for this.
Think of an inside out stud exiracter. It's a socket with a series of cutting edges that dig in.
It effs the lock, but does not touch the wheel.
'72 911T gone
'85 TVR
Old 11-22-2003, 01:38 PM
jakermc's Avatar
Some have had success pounding a socket onto the end of the lock. Pound it on hard enough and you can use a ratchet to remove the lock. Got the locks off my Boxster S that way.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 11-22-2003, 01:46 PM
Eric Coffey's Avatar
jeff m & jakermc:
This appears to be the old-style lock, wich is basically a tumbler on a tube that uses a special hollow lug nut. The tube rotates freelty, so a socket or reverse easy-out might not do any good.
If you don't have air, the Vice-Grip method works nicely. The tumbler is simply crimped/peened in place on the tube, so with a little time you should be able to deform the tube enough to get it off. Or simply use enough force to pull it straight off (bending the lock tab). You could try to rig up a slide hammer as well. Good luck!
Old 11-22-2003, 02:00 PM
dickster's Avatar
cheers eric, the vice grips sounds easy......we'll see!
Rich
'86 coupe
"there you are"
Old 11-22-2003, 02:13 PM
sammygon1's Avatar
A socket just big enough to be hammered on works well. I have lost of success with that method.
Sam Gonzales
'69 912 2.0 -6 power
Old 11-22-2003, 02:25 PM
the spinning outer shell is the problem. it's gotta go. the sockets and the inner toothed tool work well on solid mc gard locks.
206 637 4071
Old 11-22-2003, 02:47 PM
Formerly bb80sc
Vipergrün's Avatar
Yuck...I just went thru this after losing my keyed socket. I had the other type of *locking* lugs and used the shop used one of those sockets with the reverse teeth. Wicked looking thing inside. Anyway, I ditched the aluminum lugs all together in favor of the steel ones.....
Best of luck!
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 11-22-2003, 05:51 PM
nice doggie
Hetmann's Avatar
I would hit t with a 4" grinder fitted with a cut off wheel. That should buzz right through the outer sleeve.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 11-22-2003, 06:09 PM
Send a message via AIM to msailer
I used a pick and got the 4 locks off my brothers car in less than 2 minutes. If you are worried about damaging your wheels, go visit your local locksmith. These are the cheapest locks around and extremely easy to pick with a paper clip. Bend it so it looks like this, aka a lock pick.
Rake the pick back and forth in the lock. Use the a small screwdriver to turn the lock, putting turning pressure on the cylinder while you rake the lock. You will get it to unlock very quickly.
Old 11-22-2003, 09:12 PM
maxnine11's Avatar
maybe the above post should be deleted once the Dickster has read it
max
Old 11-22-2003, 09:28 PM
dickster's Avatar
i think i have the spinning type barrels, but what are you referring to - the wheel studs??
i have an angle grinder, but i thought it might make a mess of the wheels unless i covered them.
thanks for all the ideas. i'll let you know how i get on.
Rich
'86 coupe
"there you are"
Old 11-22-2003, 11:56 PM
dickster's Avatar
well, i tried the pick the lock method - no good (i'll never make a good thief).
soooo, i got out a centre punch (no chisel avail.), and hammered it into the small gap between the outer barrel, and the lock mechanism. turns out the lock part is very soft and it only took a couple of minutes to break it up enough to release the barrel.
job done
Rich
'86 coupe
"there you are"
Old 11-23-2003, 03:31 AM
