canna change law physics
red-beard's Avatar
CIS - Hot idle problems
I've made 2 runs to Vegas with my 1982 SC. After the first drive to Vegas, I pulled off the freeway. The engine seemed like it wanted to stall. The RPMs would drop and it would try to recover. Most of the time it would catch itself and pull back to 800 or so RPMs. It seems to happen with engine breaking, stall occuring when I use the clutch.
It didn't happen on the way home last time (October). But it happened twice on the way home this time (Yesterday Dec 7th). 1st time was after 1 hour of driving. The car runs fine on the freeway.
I'm thinking something to do with either the advance/retard on the distributor or something to do with the CIS deceleration system.
Clues? Hints?
James
Red-beard for President, 2020
Old 12-08-2003, 05:14 PM
vash's Avatar
vapor lock? does it happen more often on a empty fuel tank? i think the fuel recycles back into the tank, therefore it dissipates heat there. i am sure smarter folks with jump in soon.
good luck
cliff
poof! gone
Old 12-08-2003, 07:42 PM
red-beard's Avatar
Nope, even after filling it seems to happen. But even a short cooling off seems to help.
Hmmm. Fuel pump?
James
Old 12-08-2003, 08:58 PM
HarryD's Avatar
Check the CIS Troubleshooting chart here: http://www.pelicanparts.com/911/technical_specs/911_cis_troubleshoot.htm.
I had a similar issue and found out I was way too rich.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-09-2003, 10:47 AM
