Certified Pre-Owned
Howdy...
While trying to remove "Z" height out of my seats for additional helmet clearance, I started playing with my mounting options a little. One thing I concluded was that if a factory seat or an aftermarket seat is bolted directly to the floor, it would be left-of-center to the steering wheel (i.e. steering wheel is no longer centered in front of you). My conclusion was that regardless of the seat, due to the width of the shift tunnel hump in my '84 911, whatever seat I go with the seat bottom can be mounted no lower than the shift tunnel top. Can anyone confirm this? It seems as though you are dependant on finding a seat with very low bracket mounting surface-to-butt pad height to remove overall height so a helmet would clear... I am 5'8" with a long torso, and have a sunroof coupe. Currently looking at an Evo 2 seat... Having the wheel a 1/2" off center will drive me nuts... Thanks for any additional insight... Brian
'84 Carrera Coupe |
I don't know if this is the direction you're heading, but when I installed Evo 2s in my '76 (non-sunroof coupe), I used the factory sliders along with the steel Sparco seat mounting brackets. This ended up being way too tall. I was sitting higher than a stock seat.
I ended up doing away with the factory sliders and mounting the Sparco brackets directly to the factory seat mounting brackets. I had to drill some new holes and of course I have no fore/aft adjustment, but I'm the only one that drives the car anyway. With this bracket mounting and seat mounted in their lowest settings in the Sparco brackets, I sit very low in the car. Works great. I probably have a digital pic at home somewhere.... Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Brian, if you had not told me I would not have of known.
Are you saying if you mount the EVO 2 seat at the tunnel height you wont have room? What if you slide the sun roof liner out of the way for track days? This will buy you some room as long as your seat position is under the sunroof which I suspect it would be. Joe, sitting slightly to the left of center.
Joe Last edited by 85eurocarrera; 12-15-2003 at 08:31 AM.. |
Certified Pre-Owned
Hey guys...thanks for the input.
Well, from what I have seen it doesn't look like you gain much just changing the seats, unless you sink it in down to the floor pan. And then you sit off center... I just don't want to spend $600 on a seat, drop it in the same location on the factory brackets and find out I gained no additional clearance. What is frustrating is that neither Sparco or Recaro offer PDF documents with detailed dimensions on mounting locations, etc. I'd like to do my brackets and welding before I install the new carpet and trim. AND if anyone has PHOTOS of their brackets, etc. I;d sure like to see them, even if from a different vintage of 911. TIA... -BG
'84 Carrera Coupe |
BG, I am addresing this problem with the Corbeau CR1 seats that I just purchased. The CR1's sit higher than stock seats. I do not want to cut & fabricate new mounting points. So I recline the seat & sit lower in the Cr1 seat than I do with the stock seat. I will just have to get use to the new position before my next DE. If anyone has a better suggestion, I am open to hear it. This is a beget situation. I wanted a 6pt harness, so I needed new seats. The CR1 seats are well made seat but the cloth attracts lint like a magnet, & it just fits you differently. I got the fat- boy seats & there is plenty of room. Good luck in your search. Craig
80SC |
The factory seat position is not centered on the steering wheel. The seat is skewed slightly to the center of the car. Sounds like your solution is about the same.
Chuck Moreland - elephantracing.com - vonnen.com |
Certified Pre-Owned
'84 Carrera Coupe |
Certified Pre-Owned
bumpin'
'84 Carrera Coupe |
Thread Killer
I had my brackets lowered on my carrera, and they are below the tunnel. I gained a full inch of helmet room with the factory seats. However, the tunnel had to be "massaged" at the very rear of the seat travel point to keep from interfering (you can barely see it at the far right of the pic below).
Let me know if you have any questions, I'll try to help.
Allen '85 911 Coupe '75 BMW 2002 '02 Ducati Monster 900ie '18 GMC Sierra Denali 6.2L 4wd |
Certified Pre-Owned
Thanks Allen...looks like maybe it was massaged with a sledge...?
-BG
'84 Carrera Coupe |
Thread Killer
I prefer not to think about it, but yes a specialized blunt heavy instrument was repeatedly utilized during the precision modification procedure.
![]() It's really not as bad as it sounds, and after a re-coat of black spray paint, it isn't very noticable unless you are looking for it. The necessary added clearance at maximum seat travel was only a 1/4" or so.
I have a vintage 80's set of recaro's in my car mounted on the factory seat brackets. It lowered the sitting height about and inch I'd say. Guess the seat rail mounting plane to bottom cushion dimension is where it differs. Don't know if this helps.
'95 993 - street toy '99 Miata - track rat '04 RX8 - family car '83 Volvo 242 Turbo -vintage toy '03 Civic Si - hot hatch '17 Transit T350 - work vehicle '06 Earthroamer - adventure rig |
Certified Pre-Owned
'84 Carrera Coupe |
I ordered the floor mount brackets so I wouldnt' have to worry about seat height.
I don't mind cutting and pasting though as I'll be the only one driving the car and don't plan on keeping it anywhere near stock ![]() Adam
1978 911SC 3.0 (former) a_roseneck@hotmail.com |
BG how tall are you?? I had the same problem with my 84. Bought a Sparco sprint and fabbed up some angle iron adapters. Put in the Sparco sliders and voila,,I fit with my helmet! Of course, I am only 5' 10, but I could still lower the seat atleast another inch and a quarter. I just bolted the angle iron to the in board sides of the stock seat rail consoles.
Hope this helps, Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Both my son and I are over 6'3" and long torso'd. We both touch the cieling now and helmets would be impossible. So far Tuetonics solution looks the best as we need to gain real height from the mounts and also from less thick seat cushions. Thanks everyone for the quick responses. Pete
seat height
I had this problem in my Euro Carrera,
I am 5' 10" and with the helmet on I had to srunch my butt forward to keep from ending up compresing all of the disks in my neck! Needless to say this didnt make having the harness on a worthwhile thing since I could slide all around. On my stock seats between the mounting tracks and the seat bottom I found that there was a stack of 2 aluminun spacer blocks that are approx. 3/4" each. I removed them and re-installed the seat without them, I had to get some 8MM (?) grade 8 bolts that were only about 1 1'4 long. It was a bear to get in there with a socket but the end result was well worth it. I still have to do the other side. I think the way to go is probably to use allen bolts so there isnt any issue with the sockets. Good Luck! Rich 77 Carrera 3.0 (Euro) |
Certified Pre-Owned
You had the optional riser blocks for short people installed. I found those under my drivers seat and yanked them out too...
'84 Carrera Coupe |
I thought it was interesting that the Allen bolts securing my seat rails were metric 8.8 which is actually a bit weaker than regular grade 5. Then I looked up the shear strength of a 1/4" grade 5 bolt and saw it is something like 3,500 lbs. 6 bolts x 3,500 lbs/bolt = 21,000 lbs = 10 g x 200 lb me. Enough strength, d'you think?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
I didn't re-check or follow your math, but....
In general...Euro 8.8 is commonly taken to be equivalent to US grade 5. Shouldn't be a problem... --Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
