chrisp's Avatar
Engine will be out for clutch...what else should I do?
I am dropping it this coming weekend or next. My first time.
The main reason is to change the clutch. Going with a Sachs power clutch. I have come up with a list of things I want to do while the engine is out. Some are engine related others are not but are being done because it'll be easier with the engine out.
Here's my list:
A thorough cleaning
Clutch
Oil return tubes (2 are leaking)
Plug wires (very cracked)
Cap and rotor (original???)
SSI's
requisite SSI compatible muffler
Plugs
Valve Adjust
Fuel filter
Install rear shocks
Carerra tensioners
Sport Engine/trans mounts
Valve cover gaskets
Fan belt
Is there anything else I should attend to while it's out? It's a stock engine. In the 3+ yrs I have owned it I have only done a valve adjust, oil changes, pop-off valve, and a new alternator.
Old 12-23-2003, 02:00 PM
makaio's Avatar
If it's a CIS car, check all hoses and connection for tightness. Here is a small list, I'm sure others will have more:
New clutch cable & helper spring
Check release fork
Flywheel seal
Oil cooler seals
OIl thermostat "O" ring
Carrera tensioners if you don't already have them
Oil breather hose
Old 12-23-2003, 02:10 PM
chrisp's Avatar
I always forget this part
It's an '83 SC
Old 12-23-2003, 02:15 PM
greenmonster's Avatar
It's an '83 SC
Crisp, just ad a signature to your profile.
Click the button, edit profile, and fill in the "Signature" section w/ your car's info. You'll never forget again
Old 12-23-2003, 03:40 PM
David's Avatar
If you're installing one piece oil return tubes, you'll need to pull the heads. If you're doing that you might as well replace any Dilivar head studs and get a valve job.
Old 12-23-2003, 03:43 PM
Danskman's Avatar
chrisp...
I'm going through the exact same exercise. A couple items on my list that I didn't see on your's;
oil pressure switch
oil breather gasket
flywheel seal
main shaft seal (tranny)
cv joint gaskets
bell housing (throttle) bushings
oil tank to engine S hose
clutch cable / clevis / snap clip
oil t-stat o-ring (already mentioned)
oil cooler seals (already mentioned)
collapsable oil return tubes - don't have to pull the heads to install
engine compartment seals - front and rear
engine compartment soundproofing
Isn't it fun? It's like having a house that's so old, if you need to replace a faucet, you end up replumbing the whole house! And since you've got the floor torn up, may as well put new tile in... and the new tile won't match the old carpeting... and the new carpet won't match the furniture...
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 12-23-2003, 04:22 PM
It's a good time to clean and paint everything to make it pretty.
If your rear shoks need changing now is agood time.
bk
Old 12-23-2003, 05:19 PM
rdane's Avatar
Cams
Old 12-23-2003, 07:55 PM
Metal Guru
911nut's Avatar
Add a lightweight flywheel.
Clean and detail the engine compartment.
Replace the sound pad.
Remove the fan and housing and get them powder coated.
Have the valve covers bead blasted or powder coated.
Are you pulling your transmission too? Replace the shift rod seal.
Clean the transmission.
Sandblast and powdercoat the engine and transmission hangers.
Detail the halfshaft assemblies.
This is all in addition to everything else listed on the other posts.
Do everything and you'll get your car back on the road next October (ask me how I know) .
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 12-24-2003, 05:11 AM
chrisp's Avatar
Thanks for the input.
You guys are real good at spending other people's money
-Chris
'83 SC
Old 12-24-2003, 05:40 AM
Silveresrty911S's Avatar
With all those "while I'm in there" items it looks like it might be in line with just throwing in a 3.6
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 12-24-2003, 06:02 AM
Irrationally exuberant
ChrisBennet's Avatar
At a minimum replace the oil pressure switch and thermostat O-ring. If you have the flywheel off I'd replace the flywheel seal but otherwise I'd leave it and the transmission one alone if they aren't leaking. It isn't a big job to pull the motor if these start leaking and my labor is free. I'm probably in the minority on that one.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-24-2003, 06:37 AM
How about these items that haven't been mentioned:
-shifter input shaft seal on tranny
-2 output shaft seals on tranny
-front main seal
-injector o-rings
-if you do the rear main seal, you will need to get new flywheel mounting bolts
-also if you remove the flywheel, may as well replace the pilot bearing
These items are all cheap and easy to do while the engine & tranny are out.
You may as well do a valve adjust while the engine is out as well. It the easiest time to do it.
-Dave
Old 12-24-2003, 07:15 AM
