nostatic's Avatar
halfway there...rear deck alignment tricks?
OK, got the duck off the rear and have my original rear lid on. It is low on the upper right and shifted over to the right. Any tips/tricks on alignment? I suppose I can washer the right side up (between the arm and the lid). Also, the other thing I'm worried about is the latch alignment (ie not being able to open it back up). I dropped it and peeked to check and see if it was lined up...is that about all I can do?
Old 01-02-2004, 02:19 PM
Zeke's Avatar
Washers are the hot tip. Other than that, you just have to wiggle it around in the opening until you average all the margins. Lastly, line up the latch.
Old 01-02-2004, 02:28 PM
v9ff's Avatar
When I did mine... I used washers. Also, I disconnected the latch release cable to allow me to fully close the decklid and test fit the alignment. It takes all but two seconds to reattach the cable. Also, when you can fully close the lid, you can set the alignment as it will fit then slowly/carefully raise the lid to tighten the bolts.
Old 01-02-2004, 02:33 PM
Not Quite Banned
Thomas Owen's Avatar
Todd, the upper latch 'pin' can be shifted back and forth by loosening the two bolts. Put washers between the hinge and lid on the upper right.
Good luck,
Thomas Owen
1972 911T
1972 911S
Old 01-02-2004, 03:49 PM
Friend of Warren
Go with the washers. The factory actually used rectangular shims.
Kurt V
Old 01-02-2004, 04:06 PM
nostatic's Avatar
getting there
got the back on with a rough alignment, and the valence off. I tried to get the old thrashed valence back on for a temp fix, but I don't have the right hardware, and with the cooler up front it is really tight...since I've got to put another one up there anyway I don't think I want to go through it twice.
Old 01-02-2004, 04:43 PM
Check out Damon's response to my similiar question....
Targa deck lid question
Best,
Marc
1971 T Targa
Old 01-02-2004, 04:47 PM
Todd,
I would probably be doing the same thing you are if this had all happened to me.
I like ducktails but it's pretty hard to improve on the classic lines of our 911's. And I know I would miss my 911SC badge as I'm not sure it would look right on the ducktail lid.
If you do the rubber lip on your valence you may still have a problem with your driveway but I think it's leading edge is further back than the valence your removing so it should pick up quicker with the front wheels.
The nice thing about the rubber lip is it's rubber and is fairly forgiving if you do stike it.
I put the tow hook enforcers on my SC and stike them once in a while. But I think some little wheels mounted on the tow hooks or? would be the best way to go.
You've got a nice SC by the way
Old 01-02-2004, 05:34 PM
GB83SC's Avatar
Todd,
Why did you remove the Duck tail?
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 01-02-2004, 05:41 PM
Team California
speeder's Avatar
Car looks mucho better, IMO.
Denis
Old 01-02-2004, 05:45 PM
Unregistered
sammyg2's Avatar
Another little trick:
loosen the bolts that hold the latch pin thingy a little, just enough to let it shift and align itself in the latch, then close it and open it. If everything works smooth, torque them down.
Old 01-02-2004, 05:58 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Mixed feelings...
I think it works either way, it is a great looking car.
How about trying out the duck on the 21st??
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 01-02-2004, 06:06 PM
nostatic's Avatar
I'm just going to go with stock valence, no front spoiler. With none on the rear, I don't *need* one up front. And as long as I stay at double digit speeds, I shouldn't notice a difference.
It will be interesting to feel though after I get the stock valence back on. It felt very planted on yesterday's ride, but it also had fresh turbo tie rod ends and align/corner balance.
Old 01-02-2004, 06:08 PM
nostatic's Avatar
I don't think the 21st is going to work. In addition to work looking nuts this month, my toy budget is...how do you say..."tapped" for the next lotta months unless I manage to do some insurance magic. I think in a couple months I'll be able to work a track day.
Old 01-02-2004, 06:22 PM
GB83SC's Avatar
If you decide to sell your Duct tail, let me know. I need to replace my rear lid.
George
1995 BMW 525I
Old 01-02-2004, 06:42 PM
