Friend of Warren
HELP!!! I need a Z-block dial gauge holder
I just found out that my week old order for this from PP is on some indefinite back order and I can't finish my engine rebuild without it!!! Does anyone have one I can beg, borrow or steal???? Please, please, please? If not, I guess I'll have to rig up some other arrangement. I need the Z-block and extension. Willing to pay any reasonable price for it.
Kurt V
Old 01-08-2004, 09:15 AM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
You can do what I did. Drill a .25 x 1 x 6 inch steel bar, cold rolled is fine, on one end so that it will fit over the nearest valve cover stud. Put a washer and nut on to hold the plate still (not too tight, don't want to damage the sealing surface). Now you can use a magnetic base to hold the dial indicator. Make double sure you get the dial indicator perpendicular to the spring and valve.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-08-2004, 09:23 AM
Friend of Warren
John, thanks for a most excellent idea! I'm off to the Lowes tonight to find some .25 steel!
Kurt V
Old 01-08-2004, 09:29 AM
Stahlwerks.com
jhelgesen's Avatar
Anything works as long as its magnetic. 1/8" thick would probably work too. The bar will sit diagonally across the head.
Since I used the magnetic base, I could drop the dial indicator down in the head further and didn't need an extension.
Let me know, I may be able to dig up picture if needed.
Good luck!
John Helgesen
Old 01-08-2004, 09:33 AM
Super Moderator
cstreit's Avatar
Kurt...
If you're not in a hurry, I can make one of these for you...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-08-2004, 12:59 PM
Friend of Warren
Appreciate the offer Chris, but I want to get this damn rebuild back on track! I am going to use your pic and John's idea, along with my drill press and welder and just make a damn holder. I should have done it in the first place!
Kurt V
Old 01-08-2004, 01:02 PM
Friend of Warren
Originally posted by Wayne at Pelican Parts
Just confirmed - it's going into our FedEx pile right now...
-Wayne
Wayne, greatly appreciated!
Kurt V
Old 01-08-2004, 01:29 PM
Heck!
Now why isn't there an equivalent of Pelican Parts here in the UK?
You guys are spoilt rotten.
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 01-09-2004, 09:21 AM
