Question Info Request
I'm looking at an 89 Carrera Cab. Just moved to SoCal and I need to be toppless. Any way what can you tell me about these cars? What's the most miles you've seen? Anything i should know in particular? Was this a G50 car?
Bruce
Old 01-12-2004, 06:33 PM
Friend of Warren
Yes it is a G50 car. Miles really don't matter if you get a good PPI`
Kurt V
Old 01-12-2004, 06:41 PM
lally911's Avatar
87-89 cars had the G50 transmissions.
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 01-12-2004, 06:43 PM
What is the Hp rating?
Bruce
Old 01-12-2004, 06:50 PM
Did you get the memo?
onewhippedpuppy's Avatar
http://www.idee.demon.nl/ Gives an overview of the 911 over the years and some tech data. Good primer for 911s.
‘07 Mazda RX8-8
Old 01-12-2004, 07:58 PM
Eric Coffey's Avatar
If everything checks out, and the price is reasonable, you can't go wrong with a 1989 911. As Kurt said, the miles are not as important as the condition/care. If you must have a cab, make sure to check thoroughly for rust (from leaky top). Good luck!
Old 01-12-2004, 10:08 PM
Build date after April 89 would indicate that the factory fix for the transmission operating shaft bearing supports was in-place.
If earlier than that...look for repair records, using either factory or aftermarket fixes...because it will bite later. First signs are a very stiff clutch.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-14-2004, 09:50 AM
