drag racing the short bus
What is a compression point worth?
Given all things equal in two 3.0 engines, what do any of you guess would be the horsepower difference if one engine had stock 8.5:1 compression, and the other stock 9.3:1 or maybe something like JE Pistons at 9.5:1?
Thanks.
The Terror of Tiny Town |
Approximate HP increase per compression point is 10%/point.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) Last edited by kstylianos; 01-12-2004 at 02:22 PM.. |
PRO Motorsports
I've heard more like 3% per point. But it is a parabolic curve. The higher you go, the lower the gains. Diminishing returns, as they say.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Here is the formula from a past link for 2 points increase.
theoretical thermal efficiency n(rc) = 1-(1/rc)^0.4 (See curve above) Then: 8.5:1 gives n=57.5% 10.5:1 gives n=61.0% making for a theoretical jump of ~6% (180HP -> 191HP with 6%) Here is the link. The effects of higher CR
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
I believe you're thinking of a logarithmic curve, but it depends on what you're plotting. If you're doing hp (y axis) v. cr (x-axis), maybe it would look like this:
![]() But then again, would hp start to drop if you kept increasing cr? So maybe it would start back down... |
Author of "101 Projects"
Just do a comparison of some older 911 engines. Some models had varying compression ratios with all other components being nearly the same. That will give you a good baseline to start with...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Here are the curves for a 3.2 published by Bruce Anderson.
very interesting.. I'm thinking of upgrading my ~9.0:1 2.4E to 10.5:1 and twin plugs. So in reality it should only make another 10-12HP out of it?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
