scca_ita's Avatar
Need help with tachometer
I have a 74 tach and I was told that there is a separate piece (transducer?) that is located in the rear to the left of the engine.
I need this piece. The newer tachs (74plus) have this piece inside the tach.
I am trying to get the tach to work with a 3.6 Motor. other suggestions?
Old 01-19-2004, 01:48 PM
Lorenfb's Avatar
Your old tach requires a high voltage signal from the coil and not from the DME
output. I don't remember ever seeing a tranducer on any early car. Just connect
the tach wire (purple/black) to coil side which goes to the ignition unit.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-19-2004, 08:09 PM
Early_S_Man's Avatar
Porsche Crest
NO, no, no ... none of the 2.4 or 2.7 tachs required the ballast-resistor assembly mounted on the relay/fuse/regulator panel! It was phased out during 2.2 engine production.
As far as the 2.4/2.7 tachs go, some will work with the DME output, and some won't ... it is a matter of sensitivity. The Voltage 'swing' of a DME signal is not quite as great as the solid-ground signal from points ... and the 100 Ohm pullup resistor to +14 Volts.
Give the tach a try hooked directly up to the DME signal ... it won't hurt the tach, and it might work fine!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-19-2004, 08:34 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
My 74 tach worked just fine with the 3.6 until I swapped everything for 964/993 gauges. Just give it a try. I am sure it'll work just fine.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-19-2004, 09:26 PM
scca_ita's Avatar
I did try it briefly before I discovered my engine was crap and needed rebuilding, and it did not work.
When I sold the previous engine I gave the new owner everything on the panel next to the engine. So when the tach would not work I started to wonder if I gave away something I needed.
I also had some strange issues with the alternator light, When the key was in the off position the light stayed on. So I will be chasing this down too.
I did talk to Patrick Motorsports today, in their conversion harness they put a voltage amp to raise the signal out of the DME for the earlier tachs so I need to check this to make sure there is no issues with the soldier connections.
Old 01-19-2004, 09:38 PM
Porsche Crest
An IRF9630 or IRFD9123 HEXFET buffer ought to do the trick ...
Warren Hall, Jr.
Old 01-19-2004, 09:54 PM
Dr.Benzin's Avatar
Sorry about my "english" guys !!!
Taco-Tachmeter- or what ever you call it, please try it in my langvitch: "turteller"
Thanks for all the advises !!!
Old 04-08-2007, 06:23 AM
