Rear jackstand location while doing suspension work?
Searching the archives didn't turn up any info here...
Where do people usually put rear jack stands when they are doing work on the suspension, and can't put them on the torsion bar covers?
1968 911L
2004 Dodge Dakota SLT Plus
Old 01-25-2004, 09:01 AM
You can put them on the inboard sections of the torsion bar tube (closer in toward the transmission). About 10" or so in from the covers.
Old 01-25-2004, 09:03 AM
Bill Verburg's Avatar
I like to use the corners of the tub where a garage lift would pick. Place wood blocks atop the stands.
Bill Verburg
Old 01-25-2004, 10:43 AM
Randy Webb's Avatar
OK, Bill, I just have to ask -- esp. because of the recent thread and your post -- what's the deal on those wheels?
Old 01-25-2004, 10:53 AM
The deal is they were the biggest/lightest combination available at the time of purchase, 17x8 235/45 & 17x9.5 275/40
Bill Verburg
Old 01-25-2004, 11:00 AM
I don't know about those later cars, but I've only got pretty flexible thin sheet metal where it looks like those jackstands are.
Right now I've got them on the inboard side of the rear torsion tubes near the transmission mounts, and just ahead of the front torsion bar bracket in the front. Seems to be stable.
1968 911L
Old 01-25-2004, 11:32 AM
The corners of the tub are very strong. That is where a shop lift picks from.
Bill Verburg
Old 01-25-2004, 12:03 PM
Early_S_Man's Avatar
Porsche Crest
Official Porsche dealership lifts built after the 1969 Porsche-Audi joint venture used flip-up pickups which lifted just inboard of the torsion bar bushing housing ... bearing directly on the torsion bar tubes with a crescent-shaped notch, outboard as far as possible. That same position is where I have always advocated putting jack stands for brake or suspension work!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-25-2004, 12:35 PM
Gon fix it with me hammer
svandamme's Avatar
mine has damage from the PO who obviously jacked it up on the corners of the tub.
the joining of the floorpan and the rocker panel is flattened and because of the stress on the corners, the middle section kinda folded open enter a rust spot....
my vote is on the torsion bar tubes and the right sort of axle stand
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-25-2004, 01:51 PM
Corners of tub is the correct area if you look at the factory manuals or even your owners manual. Look also at Bruce Andersons Performance handbook and note where the small pads were welded-on by the factory in the back for the 87+ models. Same place for the earlier cars....roundish portion of the upward bend of the tub in the back, and close to the botom seam whee the front wheel well kicks up...might even crush the seam slightly on the front locations.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-25-2004, 02:36 PM
I have numerous pads like this one for lifting on a seam, should that be necessary, rarely is except on Audis
Bill Verburg
Old 01-25-2004, 03:06 PM
Randy Webb's Avatar
OK, can somebody flip their car over and phot the exact best lifting and jack stand points....
Old 01-25-2004, 04:18 PM
Close enough?
Bill Verburg
Old 01-25-2004, 04:56 PM
Randy Webb's Avatar
Not really -- somebody is till going to ask questions about it -- wait & see....
Old 01-25-2004, 05:00 PM
Not a bad job of flipping Bill You could have turned the picture upside down though...
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 01-25-2004, 05:03 PM
Embs's Avatar
Unless this is an old picture it appears Mr. Verburg is missing 3.8 liters of horizontally opposed fun?
Originally posted by Bill Verburg
Close enough?
Old 01-25-2004, 05:56 PM
