chrisp's Avatar
Do I need gasket sealer on output seals for my 915?
I put new seals in last night and realized that I may have needed to put gasket sealer in there. Is this a mandatory or optional? I certainly don't want them to leak later so if I need to remove them and buy new ones I will but if we think they'll be fine dry then I will keep them as is.
There were a bear to get out. Much harder than the flywheel and pulley seals. A much tighter installation too.
'83 SC
Old 02-05-2004, 04:25 AM
Irrationally exuberant
ChrisBennet's Avatar
Unless you scratched/gouged the outer sealing surface getting the old ones out, dry should be fine.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-05-2004, 05:22 AM
