Do I need gasket sealer on output seals for my 915?
I put new seals in last night and realized that I may have needed to put gasket sealer in there. Is this a mandatory or optional? I certainly don't want them to leak later so if I need to remove them and buy new ones I will but if we think they'll be fine dry then I will keep them as is.
There were a bear to get out. Much harder than the flywheel and pulley seals. A much tighter installation too.
'83 SC |
Irrationally exuberant
Unless you scratched/gouged the outer sealing surface getting the old ones out, dry should be fine.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Thread Tools | |
Rate This Thread | |
