protecting my bare shell
im about to get my 911 tub blasted but the body shop that its going to gets quite damp at night, even with a dehumidifier running all the time. whats the best type of primer to use as a good metal protector while the body is being played with? i was thinking perhaps a cheap chalky celulose primer?
also, any views on the best medium for blasting? its a completely stripped tub. Andy UK |
For blasting I'd suggest plastic bead. There are many variations of this media and it can be done without harm to your galv tub...if it's coated in the first place. Soda blasting has also been suggested on this board. I don't have any experience with it but if you can find a shop to use Soda you may want to compare.
Regarding primer, that's a tough one as primer is not designed to be a toap coat and in some instance will allow moisture to penetrate.
Warren & Ron, may you rest in Peace. |
epoxy primer?
Excellence featured a 930 daily driver with PPG epoxy primer and unpainted, owned by the PCA turbo guru. I can get more details when I get home.
Andy, Is the primer being used as a temporary rust prevetative (to be removed later) or as a permanent base. If permanent I'd suggest looking into the etching and Zinc Chromate primers.
Heck, I’m only 5 not 71!
I might be wrong but primers will not protect the metal finish from rust for any extended period of time. From what I have read about primers it is suggested that paint be shot as soon as possible. primers are porus and must be sealed with paint to prevent moisture and contaminants from getting to the metal and causing rust and paint lift (pealing) over time. Etching the metal will only protect the metal for a short period of time also (several days) and requires primer and paint ASAP. Sealing the metal with a product like POR-15 or equivelant product will protect the metal for a very long time period from moisture and rust. It would be best to shoot a layer of primer while the POR-15 is still curing to create a bond between the two. Otherwise you would have to sand the por-15 before priming at a later date. The primer will also require light sanding before painting if you leave it unpainted for more than several days. Sanding the primer would be much easier than sanding the POR-15.
I sprayed my tub with POR-15 and coated it with primer 45 minutes after the second coat of Por-15. The next day I lightly sanded the primer to remove imperfections and then shot the base and clear coat. I feel very confident that my car will not rust in the future with the POR-15 coating. Like anything else only time will tell.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Certified Pre-Owned
Be careful with your primer choice...as in *do not mix paint systems*...
(meaning don't prime with a DuPont and top coat later with PPG, etc.)
'84 Carrera Coupe |
Media blasting is great, however it will NOT remove the undercoating and seam sealer. I had my tub primed (by the powder coater) with zinc rich powdercoat primer. This is an etching type of primer providing excellent protection against rust. Speak with the local powdercoater in your area. It's a great option.
Two issues that are a result of of media blasting are: 1. wavy warped panels from high pressure blasting (the operator needs to blast the exterior body panels at low pressure to remove paint etc. and avoid warping the panels) and higher pressure elsewhere. 2. your car will leak the blasting media for a long time. It seems like it never ends! As for removing undercoating and seam sealer (that is why you are doing this right?) you have 2 choices 1. acid dip the tub or 2. countless hours with a torch and scrappers. I opted for hiring the unskilled-skilled labors to heat and scrape the undercoating and seam sealer from my tub. It will take 25-40 hours to torch and scrape this crap off, then you will find more that was missed! IMO well worth the effort, but a dirty nasty, smelly smoky job! By the way after the torching and scraping you want it blasted again. So, torch and scrape first! Good luck! Will |
Andy, Here's what one racing prep business does:
"Stripped and Acid Dipped. Everything is removed from the car, including wiring harnesses, and the entire tub is submerged in a caustic solution to remove all adhesive, undercoating, seam sealer, body filler, and paint. If rust is present, a diluted acid solution is used to remove it. The process is neutralized with water, and a coat of oil stops the chassis from rusting until the painting and body work are done. This process is the most effective and cost-efficient method of reaching bare metal. With all sealers and coatings removed, the car is as light as it can be, and in addition, all hidden rust is uncovered and eliminated. We highly recommend that the chassis be powderpainted after this process. Cost is based on weight, $1.75 per pound." http://www.autometricsmotorsports.com/products/911/index.htm#3-Transmission:
I think there is some good advice here and some things that will cause extra work. If you prime with a temporary primer, aren't you faced with the same problem getting it off for the good stuff? If you use the good stuff, you will get protection for a limited time, but not so liitle that you have to worry. Unless you just let the car sit. Therein lies its own problem; not monitoring the metal.
I vistited a well known 356 restoration shop last Fri. and the painter there leaves the metal bare until his first primer. He uses polyesther. Others here like epoxy for the first primer, but that is not a surfacing primer, i.e., for block sanding. The 356 painter states that etching primers are for non ferous metals. His opinion, not mine. BTW, the 356 shop is 20 blocks from the ocean, it's humid here too. One thing you must do is metal prep before any priming. This entails washing the car with POR MetalPrep or similar and folowing with alcohol or one of the profeesional washes lie Dupont Prepsolve. If you monitor the metal and wash it down with the acidic metal prep, theorectically, you could leave the metal bare for months while working with the restoration. My take is that each job is different, you have to go with what works in your situation. Here's my plan for the exterior: Hand strip and local blast rusty pitted area. Followed by metal prep and epoxy primer and move to the next area. When all stripping is done, prime all areaa with polyesther sanding primer and block out/repair as necessary. Seal and paint. |
Licensed User
Everything is stripped to bare metal and the first coat of POR15 is going on a front fender as a trial this weekend. Plan is to work my way to the back of the car repeating this process as I go until the whole car is primed and filled. Ive got the POR body fillers and prepping material and will be shooting 'OMNI' epoxy primer on top of the POR. |
thanks for the info people, i kind of like the idea of hand stripping (call me a weirdo if you will!) so as not to fill the car with crap, also im thinking its probably going to be a cheaper option, assuming i dont factor the labour cost into things. im now off to do a search on "POR15" to find out all about it!
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Epoxy is an excellent choice for restorations, it has great adhesions characteristics and is excellent at corrosion protection. The great thing about epoxy is you can use polyester filler (Bondo) on top of it. This procedure id recommended by Porsche, Mercedes, Lexus, Jaguar and roll Royce.
Bryan
86 Targa |
epoxy it is then! thanks blokes.
Bead blast/soda blast shell. Hit with etch & epoxy primer straight away. Then start thinking about repairs. Current thinking sways largely in favour of filling over a painted surface rather than bare metal.
POR 15 is good, although I'd rather stick with a manufacturer's complete sytem on external panels. Maybe POR shot tacky then wurth underseal on underguards and exterior floor? Whatever it is..think rust rust rust, and decide what is best to stop it. Good luck, Matt
'72 911 T/E Silver Targa |
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD 1987 930 - SOLD 1983 911 SC Targa - SOLD http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else |
And for those of us on this side of the Atlantic....they can be found at http://www.por15.com/
Good luck with your project and let us know what you do...I plan to strip a chassis in the upcoming months. So it is true that sand blasting doesn't take off the undercoating? I thought it did? |
Typical media blasting wont take off undercoating because the rubbery make-up of the coating absorbs the impact of the media.
There may be some high end equipment that is capable of this. Are you thinking of the Zinc coating on the metal?
Reason I ask is because I went on a tour of my local blasting/powder shop (http://www.ascoweb.com) and they claimed that their media blasters can run at such high pressures that they take off everything....so high that they can damage or bend the metal if they're not careful. Perhaps I should ask them if they can take off undercoating.....They do have media and pressures that are more delicate, especially for galvanized surfaces. I would love to zinc coat the metal, however I believe that's exteremely expensive? What about a rust inhibiting powder coat that has some sort of zinc chromate? My local blasting/powder shop can take the chassis directly from the media blaster to the powdercoating area within the hour. They routinely do government contracts which require rust inhibiting primers that withstand ocean/salt conditions so I would imagine that they could do a similar coating for an early 911. |
REAL zinc chromate will kill you. They don't even use it in the aircraft industry anymore. I would steer clear, or use Zinc Oxide.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Nic,
Your local blaster sounds like a good, high end shop. How's the pricing? Also, I purposely used the term "typical" for both home and business. Most businesses I've dealt with didn't quite have the industrial strength capability you speak of. Around here seems those caliber shops are after commercial business.
