pjv911's Avatar
Send a message via AIM to pjv911
Which type of head stud does the 1992 c2 turbo use
Is it dilivar or steel ?
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-07-2004, 07:12 PM
Kurt:
Those will likely be Dilavar.
You can confirm that with a magnet,.......
Steel ones stick, and Dilavars do not.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-07-2004, 08:46 PM
pjv911's Avatar
Thanks steve. Im about to install a very low mileage motor in my project car. It has been sitting for a while now and im hoping for steel units . Ive read that the dilivar studs can corrode causing them to snap . I would not be very happy with that since I allready have enough work to do. Starting the engine up and expanding for the first time in years sounds pretty risky. I will give it the magnet test on monday.
Kurt Williams
Old 02-07-2004, 08:51 PM
Good man.
If they prove to be Dilavars, I'd strongly suggest that they get swapped for the 993 TT Dilavar ones. I'm no fan of steel studs on Turbo motors.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 02-08-2004, 12:18 AM
Bill Verburg's Avatar
The ones that Steve and most knowledgable builders are recommending are
993 101 170 51
used on 964 3.6t, 993RS and 993tt
Bill Verburg
Old 02-08-2004, 08:59 AM
