Which type of head stud does the 1992 c2 turbo use
Is it dilivar or steel ?
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Kurt:
Those will likely be Dilavar. You can confirm that with a magnet,....... ![]() Steel ones stick, and Dilavars do not.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 02-08-2004 at 12:16 AM.. |
Thanks steve. Im about to install a very low mileage motor in my project car. It has been sitting for a while now and im hoping for steel units . Ive read that the dilivar studs can corrode causing them to snap . I would not be very happy with that since I allready have enough work to do. Starting the engine up and expanding for the first time in years sounds pretty risky. I will give it the magnet test on monday.
Kurt Williams
Good man.
![]() If they prove to be Dilavars, I'd strongly suggest that they get swapped for the 993 TT Dilavar ones. I'm no fan of steel studs on Turbo motors.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
The ones that Steve and most knowledgable builders are recommending are
993 101 170 51 used on 964 3.6t, 993RS and 993tt
