What spark plug wires are you running on your SC?
My 3.0 probably has the original spark plug wires, and when the engine gets hot, it routinely drops a cylinder, which I suspect is a marginal spark plug wire.
Is anyone using Magnecore or HotWires, or any of the other performance wire sets on an otherwise stock CIS 3.0?
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Unregistered
Magnecor 8.5
First thing I did when I got my otherwise stock SC was to replace the bad wires. Major improvement over the bad wires. |
Senior Member
I replaced all my wires, and periodically I check the condition/function of the set and replace parts as necessary. Both ends come off, and the wire itself has a crimped-on screw connector that does require a special crimping tool. JW happens to have that tool, so he can make wire sets. The stainless steel braiding is not necessary. I removed that.
Many of the folks here are wild about the Magnacore wires. They're apparently very good right out of the box.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
try NOLOGY HotWires
X/A |
I tried the Beru wires on mine and I would get seriously shocked anytime I came near them. I went back to the stock wires and just fixed my connectors and everything is fine. If they need to be replaced again, I'll probably go Magnacore.
Matt '82 911SC Targa! |
I have magnacore with good results.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Hilbilly Deluxe
Stock 964 wires.
Tom |
