techweenie's Avatar
What spark plug wires are you running on your SC?
My 3.0 probably has the original spark plug wires, and when the engine gets hot, it routinely drops a cylinder, which I suspect is a marginal spark plug wire.
Is anyone using Magnecore or HotWires, or any of the other performance wire sets on an otherwise stock CIS 3.0?
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 02-16-2004, 09:19 PM
Unregistered
sammyg2's Avatar
Magnecor 8.5
First thing I did when I got my otherwise stock SC was to replace the bad wires. Major improvement over the bad wires.
Old 02-17-2004, 06:15 AM
Senior Member
Superman's Avatar
I replaced all my wires, and periodically I check the condition/function of the set and replace parts as necessary. Both ends come off, and the wire itself has a crimped-on screw connector that does require a special crimping tool. JW happens to have that tool, so he can make wire sets. The stainless steel braiding is not necessary. I removed that.
Many of the folks here are wild about the Magnacore wires. They're apparently very good right out of the box.
Mocha 1978 911SC. "Coco"
Old 02-17-2004, 07:14 AM
Yellowbird RS's Avatar
try NOLOGY HotWires
X/A
Old 02-17-2004, 07:36 AM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
I tried the Beru wires on mine and I would get seriously shocked anytime I came near them. I went back to the stock wires and just fixed my connectors and everything is fine. If they need to be replaced again, I'll probably go Magnacore.
Matt
'82 911SC Targa!
Old 02-17-2004, 07:40 AM
I have magnacore with good results.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-17-2004, 07:44 AM
Hilbilly Deluxe
emcon5's Avatar
Stock 964 wires.
Tom
82 911SC Coupe
GTI Cup #43
Old 02-17-2004, 08:05 AM
