Anyone have a working high beam indicator light in the tach but the plastic is so dark that it cannot be seen?
Looking for a good solution besides drilling out the old plastic and using a blue bulb. Pete
TechGuy 1972 Targa 911T/S 2.7 PCA Upper Canada Region Last edited by techguy; 10-22-2002 at 07:04 AM.. |
Pete...if you solve this situation please post the results............Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
In other words another little common defect worthy of research, almost as much fun as getting a set of hood struts to work.
BTW In the last 3 weeks after 1 set of Stabilus and 2 sets of StrongArm struts I found some Meyle struts (German) here in Canada that work!! So far that is..see if they still work in 3 weeks ![]() Sorry Wayne, I wanted to order your HD units but was too sceptical after all my attempts. I didn't want to chance the customs and postage ![]() Pete
TechGuy 1972 Targa 911T/S 2.7 PCA Upper Canada Region |
Has anyone solved this issue? I got some grief during a state inspection that my indicator didn't work, but the issue is that even with a new bulb, the light barely shows in the indicator.
Bart '72 targa 2.7 |
i think this is common to the car...ditto here...they just ain't too bright.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
The light in my '86 is bright blue. No issue at all. Maybe a speedo shop would have a new blue indicator for you?
Nate Gone: '86 Carrera coupe Current: a $75 BMW 320i |
I solved this problem with an old VW turn signal warning light by installing a 6Volt bulb. Ran twice as bright as the 12V bulb.
Kelvin '67 912 New Zealand |
Do the VW bulbs have the same base type? The porsche dash light base seems pretty unique, I'm not sure wher to start looking for a 6v version
RETIRED
Yep...just won't last very long....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Did you get the memo?
You have the hood strut problem too? I ordered new ones from Pelican, and the stupid things are no better than the old ones. They just slow the hood down, they don't hold it. I need to call Pelican, since they're brand new, but unless they pay return shipping it's not even worth messing with. Meyle huh? Probably not avaliable in Great Bend KS. Ever tried the Weltmeister ones with the lifetime guarantee?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
RETIRED
On the hood shocks, I went with Marine grade shocks used for decks and portholes. Cheaper, heavier rated and stainless steel.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 03-04-2004 at 03:15 PM.. |
Isn't that the way it is, someone ask a question about a high beam indicator light bulb, and now we are talking about hood struts?????????
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Unoffended by naked girls
I used a marine-grade high-beam indicator....
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
I solved the strut problem with the German units mentioned in my post...the real key to working right > 50 degree weather. I find anything below 50 and they don't hold at all.
My hood struts work remarkably better above 50 as well.
But back to the high beam indicator. I'm not much of an electrician, how long will a 6v bulb last in a 12v system?
6V Bulb
Not very long at all
I'm not sure if this matters ?
I move the lids relatively slowly to Maybe help prevent leakage. I haven't had a problem, ever.
Mike, which struts are you using? Can I get them out of West Marine? Gotta order some boat parts now that it's March....
6V Bulb Not very long at all?
TechGuy
I never had any problems with the bulb blowing? Turn signal indicator so that fact it was not on constantly maybe helped? Have you tried cleaning the blue lens from inside speedo? If you want to try a 6v bulb I'm sure I'll have one somewhere, send me a pm with your address.
struts
