techguy's Avatar
Lightbulb High Beam indicator light - not visible
Anyone have a working high beam indicator light in the tach but the plastic is so dark that it cannot be seen?
Looking for a good solution besides drilling out the old plastic and using a blue bulb.
Pete
TechGuy
1972 Targa 911T/S 2.7
PCA Upper Canada Region
Old 10-22-2002, 06:57 AM
Cool
Pete...if you solve this situation please post the results............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-22-2002, 07:01 AM
techguy's Avatar
In other words another little common defect worthy of research, almost as much fun as getting a set of hood struts to work.
BTW
In the last 3 weeks after 1 set of Stabilus and 2 sets of StrongArm struts I found some Meyle struts (German) here in Canada that work!! So far that is..see if they still work in 3 weeks
Sorry Wayne, I wanted to order your HD units but was too sceptical after all my attempts. I didn't want to chance the customs and postage
Pete
TechGuy
Old 10-22-2002, 07:14 AM
dfw911's Avatar
Has anyone solved this issue? I got some grief during a state inspection that my indicator didn't work, but the issue is that even with a new bulb, the light barely shows in the indicator.
Bart
'72 targa 2.7
Old 03-04-2004, 09:24 AM
bigchillcar's Avatar
i think this is common to the car...ditto here...they just ain't too bright.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 03-04-2004, 09:27 AM
n8marx's Avatar
The light in my '86 is bright blue. No issue at all. Maybe a speedo shop would have a new blue indicator for you?
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 03-04-2004, 09:36 AM
I solved this problem with an old VW turn signal warning light by installing a 6Volt bulb. Ran twice as bright as the 12V bulb.
Kelvin '67 912
New Zealand
Old 03-04-2004, 11:36 AM
dfw911's Avatar
Do the VW bulbs have the same base type? The porsche dash light base seems pretty unique, I'm not sure wher to start looking for a 6v version
Bart
'72 targa 2.7
Old 03-04-2004, 02:03 PM
RETIRED
Joe Bob's Avatar
Yep...just won't last very long....
2012 ML350 3.0 Turbo Diesel
Old 03-04-2004, 02:27 PM
Did you get the memo?
onewhippedpuppy's Avatar
You have the hood strut problem too? I ordered new ones from Pelican, and the stupid things are no better than the old ones. They just slow the hood down, they don't hold it. I need to call Pelican, since they're brand new, but unless they pay return shipping it's not even worth messing with. Meyle huh? Probably not avaliable in Great Bend KS. Ever tried the Weltmeister ones with the lifetime guarantee?
‘07 Mazda RX8-8
Old 03-04-2004, 03:03 PM
RETIRED
Joe Bob's Avatar
On the hood shocks, I went with Marine grade shocks used for decks and portholes. Cheaper, heavier rated and stainless steel.
Old 03-04-2004, 03:07 PM
3.2 CAB's Avatar
Isn't that the way it is, someone ask a question about a high beam indicator light bulb, and now we are talking about hood struts?????????
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-04-2004, 03:29 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
I used a marine-grade high-beam indicator....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 03-04-2004, 03:33 PM
techguy's Avatar
Porsche Crest Struts
I solved the strut problem with the German units mentioned in my post...the real key to working right > 50 degree weather. I find anything below 50 and they don't hold at all.
TechGuy
Old 03-04-2004, 04:22 PM
dfw911's Avatar
My hood struts work remarkably better above 50 as well.
But back to the high beam indicator. I'm not much of an electrician, how long will a 6v bulb last in a 12v system?
Bart
'72 targa 2.7
Old 03-04-2004, 05:18 PM
techguy's Avatar
6V Bulb
Not very long at all
TechGuy
Old 03-04-2004, 07:01 PM
I'm not sure if this matters ?
I move the lids relatively slowly to Maybe help prevent leakage.
I haven't had a problem, ever.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-04-2004, 09:01 PM
dhoward's Avatar
Mike, which struts are you using? Can I get them out of West Marine? Gotta order some boat parts now that it's March....
Dan
1969 911T (sold)
2008 FXDL
Old 03-04-2004, 09:09 PM
6V Bulb Not very long at all?
TechGuy
I never had any problems with the bulb blowing? Turn signal indicator so that fact it was not on constantly maybe helped?
Have you tried cleaning the blue lens from inside speedo?
If you want to try a 6v bulb I'm sure I'll have one somewhere, send me a pm with your address.
Kelvin '67 912
New Zealand
Old 03-04-2004, 10:21 PM
struts
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-04-2004, 10:31 PM
