Pat S's Avatar
The best tools are home-made (915 nut socket)
UTKarman_Ghia has been spending some quality time with his 915 parts this week. But during reassebly he needed to torque down the 41mm nut on the input shaft. The problem here is that the input shaft sticks out a good foot past the nut. So a normal socket just won't work. You could probably but the special socket but there is no fun in that.
So we built one.
He picked up the parts for under $20
- 1ea 3/4" drive 1 5/8" socket (1 5/8 is 41.275mm)
- 1ea piece of pipe (non-galvanized, bigger than the input shaft)
- 2ea caps to screw on the pipe and match the diameter of the socket
First we cut the socket in half, splitting it just past the drive part.
Then we welded the pipe in between them and welded the caps on the pipe.
Then the tool was ready for use and slid over the input shaft and torque was applied.
The tool was only a partial success though since we could get the shaft to stop turning in the vice. If anyone has any ideas on how to hold it steady while we apply the 166lbs of torque, please let us know.
Anyone else have an awsome home-made Porsche Tool?
Pat/Matt
Old 03-03-2004, 08:19 PM
Cool, I like the homemade tool solutions! I have had to make several for racecar applications...
Make sure to polish out any burrs you may have put on the input shaft with the vise...
Chris
Old 03-03-2004, 09:27 PM
Eugene at Pelican Parts's Avatar
To hold the shaft still, the spline off an old clutch is the best thing to use... well, other than the correct tools. Check out marcesq's page in the following thread:
915 Rebuild Update
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 03-03-2004, 09:34 PM
vash's Avatar
man, you two make a great team! who is that i picture of?
poof! gone
Old 03-03-2004, 10:25 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
The factorty tool is a rectangular steel block with the pattern for the input shaft (where it slides into the clutch disk) cut into it off-center. It is held in a vice. Maybe you could take an old clutch disk apart and weld the metal center section to something that can be held in a vice.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-03-2004, 10:44 PM
Pat S's Avatar
915 Rebuild Update
Ha!
Great thread. That answers how you can get the synchros off too
We used the chisel method.
The problem with the clutch disk solution is that you can't put the input shaft on the clutch disk because it's on the same end as the socket. We need to support the other end.
unfixed, I'm in the BDU pants and blue hat, Matt is in jeans and brown hat
Old 03-04-2004, 04:17 AM
Irrationally exuberant
ChrisBennet's Avatar
My mechanic friend made the same tool so you're in good company. I use aluminum jaw inserts ($6 at Pep Boys) to hold the shaft in the vice.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-04-2004, 04:19 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Here's the homemade crow's foot my buddy Mark (kiwior) has for that job.
He also did what Chris Bennett did. Used a couple blocks of aluminum in a vise to hold the end of the shaft.
Kevin L
'86 Carrera "Larry"
Old 03-04-2004, 04:50 AM
Pat S's Avatar
Cool, If Matt ever checks his e-mail hopefully he can pick up some aluminum covers for his vice and give it a go.
KTL That was the inspiration for our version. At first we had planned to build that, but figured it would be a major pain to enlarge the hole. So went went with the other design and replicated the factory tool.
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 03-04-2004, 05:24 AM
Schleprock
KTL's Avatar
You're right about enlarging the hole Pat. I'm sure you've seen the other picture Mark posted:
I think Joe K down at the shop used a torch to cut the hole in the socket. Welding and cutting tools are some of the more handy things to have at your disposal. Makes life a lot easier sometimes.
Kevin L
'86 Carrera "Larry"
Old 03-04-2004, 05:35 AM
Certified Pre-Owned
BGCarrera32's Avatar
Yeah, take the spline center from an old clutch...weld a small frame to it, clamp it in a bench vise. Put the input shaft through it to hold it and hit the big nut with a giant crescent wrench...
'84 Carrera Coupe
Old 03-04-2004, 06:47 AM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
It was alot of fun making that tool. Pat did the hard stuff and I got the parts. BGC, it's fine to take OFF the nut with a cresent (assuming you dont strip it), but to put it back on you need to torque it to 166ft lbs. I dont have a cresent wrench with a torqueometer
Matt
'82 911SC Targa!
Old 03-04-2004, 07:21 AM
Actually, to torque it back on with a crescent wrench/pipe, I just weighed myself and 'balanced' my whole body weight on the appropriate distance from the center of rotation. The applied moment was the precise amount of torque required for that nut.
Oh yeah! duh...
2001 330i Sport
Old 03-04-2004, 09:33 AM
Ding ding ding ding, the BS meter just went through the roof!
I am wondering though if it's ok to impact it on. Problem is that the impact wrench is certainly not preceise and I wouldnt want to hurt that $200 bearing if I cranked it too hard.
Anybody know a way to do this?
Matt
'82 911SC Targa!
Old 03-04-2004, 11:40 AM
Schleprock
KTL's Avatar
Actually, Eugene's method is more precise than the impact wrench by a longshot.
As long as you concentrate your weight at the right point of the wrench/breaker bar, you're gonna be pretty close to the desired torque value.
Kevin L
'86 Carrera "Larry"
Old 03-04-2004, 11:59 AM
Use a 1 foot long cresent wrench
Stand on a bathroom scale, assuming you weight 166 lbs
Lean on the wrench until the bathroom scale reads 0 lbs
You have just put 166 lb-ft of torque on that nut.
It is pretty accurate.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-04-2004, 12:20 PM
If I'm reusing the nut, I just impact it back to the same spot.
-Chris
Old 03-04-2004, 12:24 PM
From what I've been told, you should not reuse the input shaft nuts, but that was from someone trying to sell me more
Matt
'82 911SC Targa!
Old 03-04-2004, 12:55 PM
Gary Fairbanks himself talked me out of buying new collared nuts when I was buying parts from him years ago.
-Chris
Old 03-04-2004, 01:13 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
And making sure the weight being applied is perpendicular to the moment arm during final torquing/checking. This method is perfectly acceptable.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 03-04-2004, 02:21 PM
