teamgomez's Avatar
Question Engine Sound Pad Install que
The engine is down, the tranny is getting some much needed tlc, and Pandora's Box has been cracked wide open. Got a new sound pad and just trying to get the thing in the engine bay bay was a challenge----add 3m 90 adhesive and it seems like this is going to be the sacrificial pad that I learn on and not the one that is going to be the final install.
Any quick tips from anyone who has cracked the code? I was told to start at the bottom and work up, but I'm afraid I'll miss the strut mount holes. Any comments out there??? Thx!
Old 03-07-2004, 08:40 PM
This may help. Many adhesives don't stick to.... wax paper. I think this applies to the 3M 90 spray glue. You can use sheets of WP to prevent the upper half from sticking while you align and install the bottom part of the sound pad. Of course, trial fit it first. Spray both surfaces per directions, apply to the bulkhead, then use a roller to apply even pressure to the pad.
Sherwood
Old 03-07-2004, 10:10 PM
The trick is to fit the sound pad without adhesive and then let it sag in its location, spray the adhesive on the body and pad, let the adhesive get tacky, press the pad up into its location, secure the clips, and apply some pressure for a minute or two.
Old 03-07-2004, 10:13 PM
Randy Webb's Avatar
there's a whole write up on this in the tech section.
if you are gong to paint, then do that first.
put a bead of some extra adhesive at the top lip also.
Old 03-08-2004, 10:10 AM
Friend of Warren
I just did mine. Worked it into place. Fortunately I have small hands and could get it tucked into the lower corners without too much pain and suffering. I then pulled out the upper right corner and glued, then upper left, then lower left then lower right.
Kurt V
Old 03-08-2004, 10:17 AM
JP911 hit the nail on the head.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 03-08-2004, 01:07 PM
teamgomez's Avatar
Nice points- all. I like the idea of installing it first and then maybe putting a small wooden dowel in across the tail strut mount points, and then spraying the adhesive. Thanks!
2004 GT3
1969 Camaro 502 ZZ BBC
1980 Weissach 911- gone to a good home in Colorado
Old 03-08-2004, 01:36 PM
