yeuporsch's Avatar
Removing bushing/vibration
I've been trying to diagnose a vibration in my 72 911. I think it's coming from the rear. It occurs at about 60mph+. I thought it was coming from the bushing. When I pull off the spring plate, I was surprised to see it has the hard weltmeister bushings. These squeak a lot and give the car a very rough ride. The bushings seem to be in good condition. I don't think they've been lathe, so they could be binding at time. I see some gouges in the inside.
I plan to change to Neatrix bushings. Would this make any difference in the ride quality? Less squeaks? I have Weltmeister in the fronts. I know that polybronze would be better, but I want to save the money for a rear swaybar. How do I remove the inner bushings, they seem to be stuck?
As for the vibration, what else can cause this at higher speed?
Thanks in advance.
John
Old 03-10-2004, 12:35 PM
yeuporsch's Avatar
help needed
Ok, I did a search on Neatrix. Now I still have the problem of removing the weltmeister bushing in the torsion tube. It seems to be stuck.
Thanks,
John
Old 03-10-2004, 02:25 PM
Grady Clay's Avatar
Number one – tire balance.
Number two – flat spot.
Number three – rear wheel bearing.
Number four – Cvs, but usually a "clunk" complaint.
Number five – repeat one and two.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-10-2004, 02:32 PM
The Unsettler
stomachmonkey's Avatar
For me I thought it was tire balance.
Bent rims.
Could still be bearing but until rims are sorted who knows.
Scott
"I want my two dollars"
"Brandon Won"
Old 03-10-2004, 03:40 PM
yeuporsch's Avatar
vibration
The wheels were all balance and alignment was done. Still there is vibration at 65+mph. How can one tell if this is the bearing or CV joints? Thanks.
John
Old 03-15-2004, 01:37 PM
yeuporsch's Avatar
P.S.
As for the weltmeister bushing, I torched the inner ones to melt it out of the torsion tube.
John
Old 03-15-2004, 01:38 PM
Friend of Warren
John are you running 205's front and rear? If the rears are no larger than 205's try moving them to the front and see if you still have the vibration. If it is gone or is now in the front you know it is either the rear tires or rear wheels.
Kurt V
Old 03-15-2004, 01:41 PM
yeuporsch's Avatar
exchanging wheels
The rears are 225. The car has after market turbo flares. The tires are unidirectional tires.
Thanks anyway.
Old 03-15-2004, 03:22 PM
CHILI's Avatar
Re: P.S.
John
Someone correct me if I'm wrong, but they should stay in the car. They should come out with the springplate. The stock ones do (vulcanized on) and the Netrix go on with Superglue (to the springplate). Although, I had to buy an additional tube of glue to do all 4.
If I had to do it over again (and I'm sure I will some day) I would just wait and go with Elephant racings polly bronze. Fronts, too. Then you could go to bed and say to yourself.... "I'm F'en done, no more messing with bushings"
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 03-15-2004, 03:34 PM
yeuporsch's Avatar
Aftermarket bushing
They were the hard aftermarket weltmeister bushing.
John
Old 03-16-2004, 12:25 PM
