chrisp's Avatar
What's the verdict? Degrease or no degrease when repacking CV's?
Both on this BBS and in other places I have heard conflicting stories about whether the use of degreasers is acceptable when rebuilding CV joints. I am doing mine tonight and would love to use some brake cleaner to get 'em really clean so as to not contaminate my fresh Redline CV grease...but I certainly don't want to hurt the bearing surfaces or cause grease not to "stick".
'83 SC
Old 03-10-2004, 11:59 AM
The reason for replacing the grease is to check for wear and to put fresh grease into the system (I know, duhhh) so unlike the outside of your engine, you don't need to be perfect. I would remove as much as possible with a lint free paper towel (or rag you never plan on using again) then repack. I wouldn't introduce a new chemical into the equasion.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis
1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916
Old 03-10-2004, 12:11 PM
Senior Member
Jdub's Avatar
I second that - don't use a stripping agent with the porous nature of the races. Just clean 'em up and repack.
Remember to be fastidious about orientation: races must match front/back and "o'clock" and balls to same locations.
John
'78 Targa in Minerva Blue
Old 03-10-2004, 12:24 PM
Early_S_Man's Avatar
Porsche Crest
Chisp,
I have used Brakleen, B-12, Varsol, even gasoline over the past 30+ years on CVs, and never any 'returns' or problems! Degrease 'til you could eat off them ...
The races aren't porous ... they're HARDENED!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Degreased mine using laquer thinner 25,000 miles ago. Worked great.
Tim
Old 03-10-2004, 12:47 PM
Even if the races are porous - lacquer thinner evaporates very quickly and does not leave much of a deposit. Thats how I cleaned mine - I'll let you know in about 10 years if it was a problem.
Randy
'87 911 Targa
'17 Macan GTS
Old 03-10-2004, 12:57 PM
chrisp's Avatar
I have never heard of degreasing being a bad thing for bearings...as long as you get the cleaner and contaminated grease out. Seemed odd to me that it would pop up relative to CV joints.
'83 SC
Old 03-10-2004, 01:08 PM
Grady Clay's Avatar
Plain ‘ol Stoddard Solvent (Safety Clean) will cut the old grease and is compatible with any petroleum based lubricant. Blow out with air and let dry before putting in new grease. I worry about even fingerprints on hardened steel parts when using lacquer thinner or brake clean.
I don’t disassemble the CV, that insures all the parts stay where they were.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-10-2004, 01:27 PM
ruf-porsche's Avatar
If you CV boot is torn, definitely degrease the joint because road dirt and grime is already mixed with the grease in the joint, which can lead to accelerated wear of the cv joint.
Old 03-10-2004, 03:02 PM
Binge User
Schrup's Avatar
Originally posted by Jdub
Remember to be fastidious about orientation: races must match front/back and "o'clock" and balls to same locations.John
I wasn't fastidious (nice word John) enough & when I tried to install them, they didn't articulate properly. If there is any galling, discoloration, or pitting I would replace them. In fact if they are the factory originals with over 100k miles, I would replace them regardless of thier condition, as they will have exceeded there service life.
Paul
Old 03-10-2004, 03:17 PM
you have to strip them down, clean to bare metal, inspect all the races for pits and holes (big pits), and be sure the cages are not cracked. you can't do it properly otherwise. what's the good of regreasing a bad cv?
206 637 4071
Old 03-10-2004, 03:19 PM
North Coast Cab's Avatar
I wiped as much grease off as I could, then I stood each end in a small bucket of mineral spirits. It really loosened up and removed the old grease. Then I took out and blew dry with the air compressor. Finally I soaked again in soapy water and blew dry again. They were clean, easily inspected and certainly free of any solvent before repacking. Also, get some disposable vinyl gloves and the repack will be much easier.
John
1985.5 944 GTS
Old 03-10-2004, 03:27 PM
chrisp's Avatar
John, at 125k miles do you think I should just replace them all? I don't have them apart yet but wouldn't mind saving the hassle if there's a good chance I am just going to repack a bad CV. I have one off and it seems very snug with no play between the two races but isn't clean yet so I cannot see races, etc.
Do you often see CV's that last much longer than 125k miles? If so I'll keep going. If not maybe I should just replace them.
'83 SC
Old 03-10-2004, 05:10 PM
I'm no expert. My p-mechanic did a little inspection last time I was over and mentioned I should repack my cv's. So I pulled the axles and cleaned as described. I had no wear marks at all and he even said they looked great. By the way, I've got 131k on my car. I guess if they are well packed and taken care of they can last a very long time.
John
1985.5 944 GTS
Old 03-10-2004, 05:21 PM
Randy Webb's Avatar
I used a Safety Kleen parts washer -- dired and let sit before greasing. Any residue should not be a problem. I have not had a problem - but only have about 1k miles on since then.
Old 03-10-2004, 06:23 PM
