Lorenfb's Avatar
Modifying a 3.2 DME Chip for Race/Street
By replacing the standard 3.2 O2 sensor with a wideband O2 sensor
and reprogramming the fuel maps, the 3.2 DME could be setup to
run optimally for race (AFR = 12.6) and for street emissions (AFR = 14.7).
The modes could be selected via a switch or some special startup sequence.
Another approach would modify the input analog circuits to the DME to set
the wideband O2 reference to be either AFR = 12.6 or 14.7.
The use of the wideband O2 sensor has many possibilities as have been
mentioned on another thread.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 03-17-2004, 10:18 AM
The Unsettler
stomachmonkey's Avatar
Someone out there is selling a system that let's you run 2 chips and switch between them.
Think Jack has one in his car.
My apologies to the person that came up with it for not remembering who you are thereby not being able to give full credit where it is due.
Scott
"I want my two dollars"
"Brandon Won"
Old 03-17-2004, 11:02 AM
Lorenfb's Avatar
That's correct, but it has one 512K EPROM with a chip-select pin to select
one of two 256K memory areas (performance/stock). It doesn't optimize
the AFR for street/race. This is on a Jack's 964 DME unit.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 03-17-2004, 11:26 AM
Administrator
Jack Olsen's Avatar
Yes, it's Ingo's No Bad Days chip.
Old 03-17-2004, 12:04 PM
bigrubberjeep's Avatar
What is the price of a DME (OEM)?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 03-17-2004, 01:54 PM
Not cheap. Why? If you need a new one you may want to consider having yours refurbed.
Warren & Ron, may you rest in Peace.
Old 03-17-2004, 02:02 PM
Well I have only owned my car for 7 days and it stalled today.
With me not kningh anything I asked what the caus emay have been for my stall this morning at a stop sign, the guy said it may be my DME.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 03-17-2004, 02:04 PM
I think he said DME Relay....
Old 03-17-2004, 02:14 PM
Sorry - I guess my noobness is even more obivous now. What is the price for the DME relay?
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 03-17-2004, 02:20 PM
Using the "Search Pelican Parts" above (Hint) I found the DME Relay to be $33 smackers. http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_fuelMO_pg2.htm#item6
Most recommend having a spare.
Old 03-17-2004, 02:32 PM
Do you agree on his diagnosis as a starting point to check?
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 03-17-2004, 02:36 PM
Make Bruins Great Again
Por_sha911's Avatar
The DME relay is one of the simplest things to swap out. Find another owner of the same year car and swap with them and take yours for a drive. If it stops stalling, Bingo!
btw, its not a bad idea of have a spare in the glovebox. Our host sells them.
Joe
Old 03-17-2004, 03:39 PM
True!
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 03-17-2004, 03:47 PM
D Hanson's Avatar
APR has also sold chips for several years that adjust to different settings. They have the hot mode, normal mode and a Valet mode. Switching is done as follows with the cruise control arm.
Step 1: Press and hold the "set" button on your cruise control. After approximately five seconds, the "check engine" light on your dash will begin to blink once per second. This will tell you that you are activating program one. This blinking sequence will continue for approximately five seconds.
After this five second interval, the "check engine" light will begin blinking twice per second. This will indicate that you have activated the second program. This process is continued to access any remaining programs you may have purchased. (three blinks = program three, four blinks = program four).
Step 2: Once you have activated the desired program, simply release the "set" button. The "check engine" light will go off, and you will be locked in that program until you change it.
90 C2 Cab Ruf Red/Blk
03 Caynne S L.Blue/Grey
03 996 TT Blk/Blk
04 996 Atlas Grey/Blk
Old 03-17-2004, 03:48 PM
