And another radio related question.
I recently removed my radio, speakers, amps, antenna and related wiring. I'm gonna listen to the "3.6 overture" and opt for a portable MP3 when I must have musica. Anyway, radio is out and there's that hole in the dash. I'd like to make it a shelf for misc. There has got to be someone that makes a DIN size blank pocket for this space. Even another make and model with the "no radio" option. Any ideas who may have it?
I guess another option is to find one of the older DIN radios that was a complete removable (not just faceplate as currently available) and use only the outer sleeve.
I really don't want to go with just the blank. Don't need the gauge space.
Any other ideas?
TIA
Old 03-20-2004, 04:25 PM
Cool
a voltage gauge
a CHT gauge
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-20-2004, 04:30 PM
vash's Avatar
a really big, rectangular cigarette lighter?
poof! gone
Old 03-20-2004, 04:42 PM
vash's Avatar
ok just kidding. what about a chassis from an old pull out stereo? you would at least have the template to cover the inside with some black plastic to fabricate a storage area. hell, you can even put a door on it.
poof! gone
Old 03-20-2004, 04:44 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Two words: eight track
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 03-20-2004, 05:18 PM
Did you get the memo?
onewhippedpuppy's Avatar
I had a Nissan that had an original double DIN size radio, I replaced it with a single and a pocket I got at a local stereo store. Check with a place that does installs, I'm sure they'll at least have something generic that you can adapt. Good call on removing the radio, you do know that a pocket will add weight though?
‘07 Mazda RX8-8
Old 03-20-2004, 05:24 PM
Just found the solution. Thanks for the response.
Old 03-20-2004, 07:26 PM
vash's Avatar
hey! share the info.
poof! gone
Old 03-21-2004, 12:05 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest radio related question
A little bit late, but....
I think this is a solution
Kees.
Old 03-21-2004, 12:36 AM
vash's Avatar
slick!
poof! gone
Old 03-21-2004, 01:22 AM
