armandodiaz's Avatar
Disconnect the battery for a couple of minutes.
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 04-03-2004, 03:24 AM
KTL KTL is online now
Schleprock
KTL's Avatar
It's my understanding that the early Motronic DME does not have any "memory" diagnostics like some newer cars. For example, an early 90's car like my Plym. Laser where you can read error codes from the ECU with a multimeter.
The 3.2 Motronic has read-only memory which is taken from the chip/EPROM. The EPROM is programmed and does not acquire and store any information to tell you how the car is operating. The car knows nothing about how it has behaved in the past and cannot "tell" you what is wrong. The car only knows how to run based upon what current information the sensors provide to the Motronic control unit as the car is running, and then the ECU decides what to do based upon the code programmed into the EPROM. The car doesn't retain any error codes or information to be learned or used for diagnosis. Therefore, disconnecting the battery does not clear anything.
That's how I believe the 3.2 Motronic system basically operates as far as "memory" is concerned.
Kevin L
'86 Carrera "Larry"
Old 04-03-2004, 03:51 AM
Lorenfb's Avatar
KTL is right on! No diagnostics or volatile memory for data in the 3.2 DME.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 04-03-2004, 06:28 AM
