dickster's Avatar
more wet carpets, drivers footwell. can't find source.....
i was doin the annual hoovering of the carpets today and found some wet patches in the drivers footwell. i had driven the car 300 miles in rain last week, and also just now washed it so it could be from either rain or hose pipe.
i had removed the mats so i was looking at the bare floor pan. There was a drip onto the floor right beneath the dash around the area of the speedo.
the other was underneath the carpet to the left side of the footwell, the side panel behind which the cables come through from the door. whats behind the area? could the water follow the cables through from the door? the top of the carpet was dry, just the backing wet.
i have had the screen seal replaced so it is not that. i wonder whether it also might be coming in from the trunk area where the master cylinder is or something...
anyone had similar leaks?
Rich
'86 coupe
"there you are"
Old 03-27-2004, 11:04 AM
kqw kqw is offline
Open your hood and pull back the carpet on the drivers side. Locate the bottom connection for the hood shock. A few inches to the left of that point you should see a plug. IF you see a hole, that may be the source.
The Fox
Carrera
Old 03-27-2004, 01:55 PM
I'd also check the bottom driver's corner of your windshield. I had a capillary action leak that very cleverly avoided detection for 6 months and yet constantly kept my left leg wet.
930 no more.
997 GT3 no more.
912 targa more.
914 now!
Old 03-27-2004, 02:43 PM
911 user
Milu's Avatar
I'd check the bottom left corner of the windscreen despite the new seal. Even if you used a silicone windscreen sealant with the new seal, a little water and some capillary action can earn you wet spot. I had two attempts on the rear and three on the front to resolve my leaks.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 03-27-2004, 03:03 PM
dickster's Avatar
thanks guys i'll check it out.
Rich
'86 coupe
"there you are"
Old 03-27-2004, 08:37 PM
al lkosmal's Avatar
bladder control problem?
RGruppe #669
http://www.x-faktory.com/
Old 03-27-2004, 09:44 PM
Glasgow 911SC's Avatar
argh. I've battled leaks the whol 3 & 3/4 years I've owned my car. Mine seems to be leaking at the passenger door. It pools on the inside of the door seal (at the front bottom corner) and overflows onto the floor where the pedal cluster bolts to. After a strong rain I get about 20mm of water down there. The plastic door lining is intact so that doesn't seem to be the problem.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 03-28-2004, 07:29 AM
AirCooledExcellence's Avatar
Ha ha you guys, you should have bought a Targa!!
Cheers,
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 03-28-2004, 07:53 AM
DOH
Chris
Old 03-28-2004, 08:11 AM
The windshield seal on my '72 leaked on the driver side everytime I drove it during wet conditions. When I finally removed the windshield & seal, I found the seal had been leaking for years & had rusted away the lip supporting the seal and the left corner of the metal under the dash pad. It was pretty bad.
Marv Evans
'69 911E
Old 03-28-2004, 08:39 AM
dickster's Avatar
chris
i feel better knowing that you poor fella! that would drive me nuts. the first thing i did with mine was replace the screen seals - have you done that?
sometimes these leaks are coming from the obvious places.
yeah, and i suppose we should be glad we dont have tim's targa
Rich
'86 coupe
"there you are"
Old 03-28-2004, 09:29 AM
yep. all window rubbers replaced and sealed with appropriate gunk. I had a leak at the back window ans sunroof but finally managed to eliminate them. It's a PITA driving around with no carpets and the passenger door card missing.
Chris
Old 03-28-2004, 01:14 PM
}{arlequin's Avatar
I'm also having the same leaks. The doors are fixable with new rubbers, but the driver-side footwell is another story. It looks so convoluted when I look up under the dash, that there is no way to tell exactly from where it's dripping. It drops on my leg right around the clutch pedal area. I will be checking for the plug by the hood shock though. Never knew about that.
What is the story with the capillary action in the windshield lower corner? Is it a "usual" place for a leak or just something that develops no matter what?
dave
1973,5
Old 03-29-2004, 08:29 AM
911 user
Milu's Avatar
Re windshield lower corners:
If you park your car in the rain, water will always pool there. If there is the slightest hint of a possibility of a less than perfect seal, some water will eventually make its way into the cabin. How much depends on how bad it is.
The windscreen place that replaced my screen and seals last year maintained the top edge of the seal by the roof was the biggest culprit at the front. I am not wholly convinced about that.
Old 03-29-2004, 09:08 AM
bigchillcar's Avatar
it's true that water likes to collect in the lower corners of both the front and rear windshields, but the place to watch for entry is actually the upper driver's side of the windshield seal. for some reason, there is more often than not a tiny opening there where the seal just doesn't cover 100%...it's where a whole lotta watah comes in...
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 03-29-2004, 06:55 PM
ART C.'s Avatar
hey glasgow 911sc.....my 71e did that. I took a paper punch and put a hole through the seal. as low as possible. Now it flows out before coming in!
Art
1971 911e Yellow cooling shroud
1995 GPZ1100
Old 03-29-2004, 08:06 PM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
point the hose at the fresh air inlet at the back of the hood--i had a monsoon-type leak that turned out to be a bad drain hose connection. the water leaks from the box into the interior, not the trunk... it hit mostly the passenger side, but it's still worth a (free) look.
-Doug
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 03-29-2004, 08:32 PM
dickster's Avatar
looks like theres a few of us with this problem.
thanks for the ideas, i'll have a look at the weekend.
i'll try and get a pic of the on the left hand side panel - thats behind the carpets, i only knew the water was there because i happened to put my hands up under the carpet there.
Rich
'86 coupe
"there you are"
Old 03-29-2004, 11:23 PM
ah! That's got to be worth a try. Thanks.
Chris
Old 03-30-2004, 04:25 AM
What?
trj911's Avatar
Make sure it's water. It could be a leaky master cylinder.
Tom J.
911SC Cab
SCWDP
CaymanS
Old 03-30-2004, 05:06 AM
