Recreational User
proper lug nut torque
OK, this should be an easy one for you gearheads.
What's the proper torque for a lug nut on an 86 Carrera? Thanks in advance. P.S. I have forged alloy Fuchs and alloy lug nuts. Last edited by porschenut; 03-27-2004 at 02:11 PM.. |
Its either 94 or 96 lbs/ft
Recreational User
Thanks, but are you sure that's for the alloy nuts and not the steel ones?
yeah, 94 lb/ft.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
94 lbs/foot is correct.
2001 Turbo |
I just talk with Tony Callas about this, he likes to torque at 85lbs. If Tony says 85, I torque at 85.
Bentley manual says 94 or 96 lbs I think.
83 SC (gone) // 72 T (gone) |
Gon fix it with me hammer
now, call me ignorant, but i've been driving cars and replacing tires for 10 years on sjitloads of different cars, and never , ever needed a torque wrench to tighten my nuts.
what am i missing here?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
What's the best oil to use?
What are the best tires? Is K&N really that good? Is 93 octane ok? Does the cool collar really work? Flame away...
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
With a recommended torque of 94 lbs/ft, if you use the "armstrong"
method, you will very easily strip alloy lugnuts. I'm also in the 85 lbs/ft camp, by the way. No hint of a loose one yet.
Mike B. '72 911E Coupe Early "S" #1065 |
130NM, with a light coating of copper grease, as per the instructions on a set of lugs from the factory.
Why would anyone use something else than the torque recomended by the guys who designed and built the whole lot is beyond me. OK, the horse is dead. |
Administrator
130 Nm is approx 96 ft lb.
Practically speaking, is there a meaningful difference between 94 and 96 ft lb?
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Recreational User
I'm in the same boat as svandamme - in 20 years of removing and replacing wheels on cars, I have never used a torque wrench. Just "nice and tight" has always worked fine, never had a problem. Is it really that important??? |
Yep....and when you tighten those alloy lug nuts, use a dab of never seeze on the rounded face of them so they don't "gall" into the wheel. Do another search, you'll find a pic posted by an unfortunate who had a nut break. When you torque, "stagger" the torque...torque every other nut. But...all that said, it is your car, so do as you please.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
"Is it really that important???"
Well, yes. Torque is used to produce tension on the most important bolts on the car. Nuts may loosen if you use the wrong torque..... if 2 or 3 do so, then you and many others could be dead. If the engine fails, you're only out $5,000 to $$20,000. |
converted that is 95.88 ft-lbs
Now it you can tighten w/o a torque wrench and by accurate, which I'm sure you can, good. But for most, a torque wrench is handy to get it right. BTW, while on the subject of torque, I had to spring for some tires for the daily ride (pickup) this week. I drove the truck straight home and proceeded to see just what they had done as far as tightening the nuts. I loosend each and retorqued my steel nuts to factory GM alloys. I don't have a beam type of wrench to read the torque coming off, just a clicker kind. My guess is that they ranged from 130 to 80 on the same wheel by feel. Just typical work for the skinheads that do this job these days. I don't even complain anymore, I just go home and redo whatever I have to have done. |
"My guess is that they ranged from 130 to 80 on the same wheel by feel. "
I wonder if that's a result of using an impact wrench? I assume that's what they used?
