Recreational User
porschenut's Avatar
proper lug nut torque
OK, this should be an easy one for you gearheads.
What's the proper torque for a lug nut on an 86 Carrera? Thanks in advance.
P.S. I have forged alloy Fuchs and alloy lug nuts.
Old 03-27-2004, 01:52 PM
Its either 94 or 96 lbs/ft
Old 03-27-2004, 02:16 PM
Recreational User
porschenut's Avatar
Thanks, but are you sure that's for the alloy nuts and not the steel ones?
Old 03-27-2004, 03:12 PM
yeah, 94 lb/ft.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 03-27-2004, 03:21 PM
Larry Harris's Avatar
94 lbs/foot is correct.
2001 Turbo
Old 03-27-2004, 03:27 PM
GrindingGears's Avatar
I just talk with Tony Callas about this, he likes to torque at 85lbs. If Tony says 85, I torque at 85.
Bentley manual says 94 or 96 lbs I think.
83 SC (gone) // 72 T (gone)
Old 03-27-2004, 03:41 PM
Gon fix it with me hammer
svandamme's Avatar
now, call me ignorant, but i've been driving cars and replacing tires for 10 years on sjitloads of different cars, and never , ever needed a torque wrench to tighten my nuts.
what am i missing here?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 03-27-2004, 03:42 PM
Rick Lee's Avatar
What's the best oil to use?
What are the best tires?
Is K&N really that good?
Is 93 octane ok?
Does the cool collar really work?
Flame away...
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 03-27-2004, 03:50 PM
With a recommended torque of 94 lbs/ft, if you use the "armstrong"
method, you will very easily strip alloy lugnuts.
I'm also in the 85 lbs/ft camp, by the way. No hint of a loose one yet.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 03-27-2004, 03:53 PM
Is 93 octane ok?
Flame away...
I think what Richard is trying to say is....use the SEARCH function!
130NM, with a light coating of copper grease, as per the instructions on a set of lugs from the factory.
Why would anyone use something else than the torque recomended by the guys who designed and built the whole lot is beyond me.
OK, the horse is dead.
Old 03-27-2004, 04:35 PM
Administrator
Jack Olsen's Avatar
130 Nm is approx 96 ft lb.
Practically speaking, is there a meaningful difference between 94 and 96 ft lb?
Old 03-27-2004, 04:51 PM
Recreational User
porschenut's Avatar
Yup, I did that and what I found is that there is no consensus on this. Most of the posts give a lb-ft in the range of 90-96, but there is TONS of disagreement all over the place. "I use 85". "94 will strip the nuts". "94 is for steel lug nuts, not for alloy". "My brother the Porsche mechanic says no more than 75". "I use 94 on the track but only 87 for the street" , etc., etc., etc.
I'm in the same boat as svandamme - in 20 years of removing and replacing wheels on cars, I have never used a torque wrench. Just "nice and tight" has always worked fine, never had a problem. Is it really that important???
Old 03-27-2004, 05:37 PM
pwd72s's Avatar
Yep....and when you tighten those alloy lug nuts, use a dab of never seeze on the rounded face of them so they don't "gall" into the wheel. Do another search, you'll find a pic posted by an unfortunate who had a nut break. When you torque, "stagger" the torque...torque every other nut. But...all that said, it is your car, so do as you please.
Old 03-27-2004, 05:56 PM
Randy Webb's Avatar
"Is it really that important???"
Well, yes. Torque is used to produce tension on the most important bolts on the car. Nuts may loosen if you use the wrong torque..... if 2 or 3 do so, then you and many others could be dead.
If the engine fails, you're only out $5,000 to $$20,000.
Old 03-27-2004, 05:58 PM
Bill Verburg's Avatar
Absolutely correct!
converted that is 95.88 ft-lbs
Bill Verburg
Old 03-27-2004, 06:03 PM
Zeke's Avatar
The front alloy hub on a Porsche looks pretty stout to me and I have no doubts about the rear hub. That having been said, not all cars are as well engineered. So, the best bet is to tighten all nuts to the same torque, whatever your pleasure as far as ft/lbs might be. Uneven torque can cause some distortion which can show up in the brakes (disc).
Now it you can tighten w/o a torque wrench and by accurate, which I'm sure you can, good. But for most, a torque wrench is handy to get it right.
BTW, while on the subject of torque, I had to spring for some tires for the daily ride (pickup) this week. I drove the truck straight home and proceeded to see just what they had done as far as tightening the nuts. I loosend each and retorqued my steel nuts to factory GM alloys. I don't have a beam type of wrench to read the torque coming off, just a clicker kind. My guess is that they ranged from 130 to 80 on the same wheel by feel. Just typical work for the skinheads that do this job these days. I don't even complain anymore, I just go home and redo whatever I have to have done.
Old 03-27-2004, 07:55 PM
"My guess is that they ranged from 130 to 80 on the same wheel by feel. "
I wonder if that's a result of using an impact wrench? I assume that's what they used?
Old 03-27-2004, 07:59 PM
