targa questions - removing bits...
Some questions for the targa knowledgeable.
1. How is the rollover hoop attached to the body? bolts or welds? (if its by bolts, then a simple bar between the mounting points - similar to a strut brace - should offer the same rigidity) 2. How is the windscreen frame attached to the body? I'm trying to determine how reversible a speedster conversion would be.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
The A pilars of the windshield frame are welded in place. A true Speedster windshield frame is shorter and at a slightly lower angle than a common 911. It seems to me that it would be a severe PITA to change one back once it has been "chopped"
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
the structural roll bar is welded. I currently have the black alum cover off mine, for refinishing.
There AREN'T any aluminum covers! Stainless prep will be a bit different than aluminum!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thread Tools | |
Rate This Thread | |
