Trans is done. Is there a special trick to getting the clutch fork back on the throwout bearing when re-mating to the engine?
I have 101 Projects but can't seem to find the tip I need. Thanks for the assistance. 1981 Euro SC
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
If everything is out of the car you can watch the guide fork through the hole in the upper part of the bell housing. If the tranny is still in the car (which I doubt since you worked on it) the "trick" is to take it out first.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Unregistered
No special trick but I had a bit of a struggle with it. Of course the tranny was in the car and the engine was sitting on a jack.
You need to pull the throw out fork away from the tranny at about a 45 degree angle or so, then carefully wiggle the tranny and engine together making sure the fork is engaged. if it is on too far they won't go together. If it is not engaged it will flop around. If it is engaged correctly there will be just a little tiny bit of slop in it. You did use a clutch alignment tool or a similar device, right? |
I didn't touch the clutch. Simply removed trans from engine. I suspected the procedure was simple. Gotta love German engineering! Sometimes I think they made it stupid simple to mess with DIY'ers.
thanks gentlemen
When doing mine we used a long screwdriver through the view hole to help ensure the fork moved as the tranny was pushed toward the engine.
Doug '81 SC Coupe |
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
