3.6 Cyl Head Temp Sensor Location...
I know it's at/near cyl #3, but does anyone have a picture, or good description of its location? Is it accessible from the engine bay, or underneath the engine? Anything special to know about changing it out? I believe I need a 14mm wrench with the end cut out for the wire...will probably use a flare-nut wrench.
I suspect it is at the heart of my cold starting problem. Any help would be great. Thanks,
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
My head temp sensor was broken upon arrival of my engine, so I replaced it during that time.
I don't know how similar it is on 993 engines, but here's the Pelican article for replacement on a 3.2. Carrera head temp sensor replacement
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
It is on the rear of the motor and has a black rubber plug over it. The wirecoming from it should be white and encased in a plastic sleeve. I believe you need a 14mm 12 pt socket that has to be cut down to fit - it is a PITA.
Divers side/front of the engine - two wires
1 from the flywheel sensor and the other to the side of it is the temp sensor. There are no other wires |
Todd, It looks like you learned a lot about that engine
First I loved VW Beetles, then 914's and 911's. To this day nothing comes close. Germans... I have been busy, but watch your mail. |
Exactly what I needed.
Thanks!
