Typical Fish's Avatar
Removing rotors...
Several posts that I found via Search refer to using a torch to loosen stubborn rotors; is there a specific technique to this? And are there any other ideas for loosening them (penetrating oil, etc.)?.
Thanks in advance for any suggestions.
Matt
Matt
Old 04-30-2004, 11:15 AM
You do not have permissi
john70t's Avatar
When using heat, remember that the whole part has to be heated evenly or warping occurs, and it has to be be heated fast before that heat transfers to the other part and they both expand.
Also, if it starts to glow, the metal is going to be softer/weaker after it cools so try and avoid that.
Old 04-30-2004, 11:29 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Rubber mallet works good for popping them off.
Be sure to clean the mating surface on the hub before installing the new rotor. Too much corrosion can cause excessive runout and result in vibration. Put some antiseize paste on the mating surface too!
Kevin L
'86 Carrera "Larry"
Old 04-30-2004, 11:44 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Rubber mallet with even, light taps. Do not want to warp the rotors and have to buy new ones.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 04-30-2004, 01:05 PM
a lot of rotors have two threaded holes where you can thread in a 8mm bolt and push them off the flange.
206 637 4071
Old 04-30-2004, 01:08 PM
Big ass hammer, and a 10 inch piece of 2x4.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-30-2004, 03:03 PM
