Jays72T's Avatar
What jack to use for engine drop?
Looks like I need to order a new jack since my cheap POS is leaving puddles just like my car. I was wondering what other people have used to drop the engine. I am looking at this for the lift hight but not sure if it's overkill.
http://www.drivewerks.com/catalog/shopcart/TOOL/POR_TOOL_ACHyd1_pg1.htm
Appreciate the help.
Thanks,
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 04-30-2004, 01:11 PM
For engines, any jack will do since the engine weighs about 500 lbs. The SEARS aluminum jack was nice since is weighs about 35lbs and is much more easily moved then the steel one that weighs 100lbs.
Old 04-30-2004, 01:17 PM
Jay, The one you link to is a beautiful garage jack. Pretty much the ultimate if weight is not a consideration.
Warren & Ron, may you rest in Peace.
Old 04-30-2004, 02:02 PM
Irrationally exuberant
ChrisBennet's Avatar
Removing the motor involved jacking the car up and off the motor at one point so high lift is important. The Sears aluminum jack is a nice looking POS just like the other $100 Chinese aluminum jacks. They are fine for occasional track use but the poor quality Chinese hydraulics/seals will be leaking in a few years just like your current one.
My friend has one of those AC Hydraulics jacks and it is very nice.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-30-2004, 02:36 PM
braddb_82SC's Avatar
I used two $50 orange Harbor Freight jacks; one borrowed and one my own. I placed one jack under the engine and used the other jack to lift the car. Three jacks would have been ideal. That way I would not have had to keep moving the jack from one side of the car to the other.
-Brad
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=4172
'82 911SC Coupe
Old 04-30-2004, 02:38 PM
How do you balance the engine on the jack? Is there an adapter of some sort?
Jim Chatfield
1972 911T
1999 Lexus RX300
Old 04-30-2004, 02:44 PM
scottb's Avatar
Some people have used ATV jacks, like this one: ATV Jack
1984 Targa
Old 04-30-2004, 02:48 PM
mackpipes
Guest
Posts: n/a
I used an ATV jack. It worked very well. Unfortunately, unless you work on motorcycles or ATV's it has limited other uses.
Old 04-30-2004, 02:52 PM
scottb's Avatar
But for $70, how can you go wrong? In fact, when you're finished with your engine drop and reinstallation, you can probably sell it to a local fellow Pelican for $50, for his next engine drop. Then he can sell for for $30, etc., etc.
1984 Targa
Old 04-30-2004, 02:55 PM
Take a look at the Craftsman motocycle/ATV/riding-mower jack. It's only $199 and is sure as hell what I'll use next time, having already once gone through the circus trick of balancing an engine on a floor jack. Never again. At that price, it makes no never-mind that I don't own a motorcycle, ATV or riding mower.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-30-2004, 02:57 PM
mackpipes
Guest
Posts: n/a
Scott, funny you should mention that. I bought mine from a local Pelicanite for $40. I'll pass it on to the next Pelican engine dropper.
I use two jacks, the 30lbs aluminum one under the tranny, and the large steel one (bought from Costco few years ago) under the engine sump cover. The aluminum one did not have enough lift to reach the engine while the car is jacked way up.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
cyprusx's Avatar
This jack rocks!!!! Cost is very reasonable for a jack that get as high as this one. I bought one for my drop last fall and would buy it again in a second. Free shipping also!!!! Check it out...
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42820
Rick
88 Carrera Targa
-- There are only those that know and those that do not!!! --
Old 04-30-2004, 03:45 PM
The motorcycle jack will keep it balanced. I have dropped and installed my engine by myself with it. I picked one up from checker for $59. It was well worth it.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 04-30-2004, 03:48 PM
cyprusx's Avatar
Yes... Use a motorcycle jack for the engine with a beefed up funiture dolly. Use the high lift jack to lift the car so you can slide your engine out. You can do it by yourself with these jacks at the ready...
Rick
88 Carrera Targa
Old 04-30-2004, 03:56 PM
I've dropped and replaced a couple of engines the last year and have come to the conclusion: You don't need either jack to lift excessively high if you place the jacks in the right spot. To jack the back end of the car up, place the jack on a 2x4 centered on the car directly in front of the transmission bolts. This will lift the car adequately to slide the engine in from the back. Once the engine is in place, jack enough to get if close and then lower the car and start bolting. 2 people and do this job, 3 is better. It is not that hard to center the engine on a board and guide it into place with light support on a jack. If you want to buy $500 jacks or specialized jack to do this possibly once in your cars lifetime, do so by all means. The economy can use the business.
Old 04-30-2004, 07:03 PM
marcesq's Avatar
Having now used the Sears ATV jack (I lend mine out freely Ted) and Paul Wilding's jack adaptor (if you have a pre 3.2 engine) which Pelican sells, I can say that Paul's tool beats the ATV jack hands down.
The engine is balanced perfectly and is level so you don't have to worry about messing up the shift shaft while lowering the car down on to the engine/tranny.
If there was one for the 3.2/3.6 blocks, I would buy it and sell the ATV to Ted for 50 bucks.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 04-30-2004, 07:10 PM
The I've been very happy with the AC hydraulics model 20. I looked at the high lift model, but figured the vast majority of the jack use wouldnt require it (other than an engin drop) and that I could use some wood boards when required for the extra lift.
Old 04-30-2004, 07:16 PM
David's Avatar
I'm unclear on how some of you slide the engine out from under the car with it on a jack.
I take off the wheels and lower the car until the engine is on a wooden dolly that I made, then I loosen the bolts and raise the car enough to slide the engine out. Even with the very short dolly, I have to lift the car pretty high to slide out the engine.
Old 04-30-2004, 07:50 PM
Jays72T's Avatar
Thanks for all the input and will try to post some pics. It seems like the motorcycle jack is a nice way to go for balance and overall ease. But with advice give here tells me I don't need a "high lift" jack to get this sucker out. I'm sure there's more questions on the way so htanks again for the help.
Jay
Jay
'08 E350 Wagon
'74 914 gone
'72 T gone
Old 05-01-2004, 12:41 AM
