WEVO Battery Box Installed
Pretty easy installation, following the directions supplied by Hayden as well as the battery location tech article that has been referenced on this board in the past. There was only one tricky part - I had trouble getting the battery to fit into the box. It is a VERY tight fit and required perfect placement and more than a little bit of force.
I ran main power cable up through the driver footwell and into the smugglers box via a new hole that was created by the removal of the AC system. The auxillary power cables were long enough to reach the battery in a direct line if I kept them in the front trunk so I chose not to extend the cables and run them along the same path. You can see this in the picture. This is a track car that never carries luggage so I saw no reason not to take a little short cut. ![]()
1983 911 3.6L - NASA GTS-3 class 1998 Boxster - PCA SpecBoxster, NASA GTS-2 2003 996X51 - NASA GTS-4, PCA GTB 2003 996 Carrera 2 Coupe 2003 Ferrari 575M |
I like it.
Nice!
Very nice! I just picked up the Rennline battery box. I plan to install it next weekend and will fire up some pictures to compare & contrast the different options available.
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
I didnt see the Rennline box at their web site - do you know where we can look at it?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Administrator
Looks great. Pelicanite Tyson Schmidt has the Wevo box in scruffy, and he's done a cool mod to incorporate a kill switch into it.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Rob,
update us after you do the install. I picked one up at Hershey as well (along with the front tow hooks). I am swamped in some other work so I look forward to you finding out how it goes.
Richard Lane 1978 911SC 1973 "Clean" RS clone |
How much did they cost?
Here's a thread on the components with pics..... Wevo battery box
Warren & Ron, may you rest in Peace. |
What is the advantage of relocating the battery to the smuggler's box? I know many do it. Does it just center the weight a little more?
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Centered weight and consolidation from two batteries to one in older cars.
_____________________________ Clint Smith www.RebelRacingProducts.com 1970 911T ----> RGruppe RS/R (mexico blue) 1995 993 becoming an RS (gran prix white) |
I'll try to remember to take pictures of the pieces tonight, but it is not a complete enclosed body like the Wevo unit. Rather, it essentially makes a cage around the battery. It was designed for one of the Optimas (a smaller one, but I don't remember the model), but it is fully adjustable and I will adapt it to the Odyssey battery.
