rdane's Avatar
First 100 Miles on a new 3.4
Finally had a chance to turn the key on my new engine this afternoon. (SC 3.0 is now a CIS 3.4)
Sounds like a sewing machine. Although it is a bit loud...louder than before. Hard to figure out exactly what is different when you are stresed about the first 100 miles and breakin.
But here are my thoughts for the moment. LOTS more torque. It used to kick in around 4K on the dyno. You can now see the cam come on and the tach jump and the car start pulling hard at between 3100 / 32OO until you let up. So much torgue I would have sworn I was in 3rd once but was actually 5th. Pulls like the proverbial freight train...even this new and @ 100 miles.
Engine came in $1400 under budget, surprizingly and came out a pretty color too More later.
Old 05-14-2004, 08:13 PM
drag racing the short bus
dd74's Avatar
Photos...
The Terror of Tiny Town
Old 05-14-2004, 08:38 PM
Binge User
Schrup's Avatar
I get all moist just thinking about it Dane, can't wait to hear it this weekend!!! BTW after JW properly adjusted my valves my motor sounds like a Singer too, he said they were way out.
Paul
Old 05-14-2004, 08:44 PM
Mark Wilson
Guest
Posts: n/a
That motor sounds more like a freakin turbine than a singer. Looks awesome too. Great job Dane!!
Old 05-14-2004, 08:46 PM
rdane's Avatar
Thanks guys. Paul the house, son and car looked great. Looking forward to seeing your "new" ride.
As you can see we back dated the heater and added a little paint in there. Best part is actually being able to see the left bank of plugs and the powder coated sump cover
Old 05-14-2004, 08:52 PM
Bye, Bye.
Scooter's Avatar
Re: First 100 Miles on a new 3.4
Yeah, going up the mountain on I90 doing 100 mph, pulling like your in 3rd...I would say there is some torque there. Seemed kinda sad getting back into my car Dane. Very impressive!
Elvis has left the building.
Old 05-14-2004, 09:01 PM
Congratulations. Nothing better than not just getting a project done, but bringing it in under budget.
Old 05-14-2004, 09:13 PM
dd74's Avatar
I like it! Very nice. Hmmm...I bet my little ring and pinion wouldn't last past the break in period with all that torque. What do you guys think? Would a 7.31 r/p last with a 3.4 like Dane's?
Old 05-14-2004, 09:20 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
From all the discussion I've seen here there should be no reason a 7:31 915 wouldn't last, if it had all the proper upgrades.
Great job, the engine looks awesome, I can only imagine how it feels. I do know torque though and you’ve got to love it!
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 05-14-2004, 09:35 PM
D idn't E arn I t
RANDY P's Avatar
Whooo Hoo!
Very nice!
rjp
AOC/Hogg 2028
Old 05-14-2004, 10:03 PM
}{arlequin's Avatar
Congrats. I was cheering for you.
dave
1973,5
Old 05-14-2004, 10:15 PM
Administrator
Jack Olsen's Avatar
That looks great -- and I bet it pulls even better. Congrats!
Old 05-14-2004, 10:19 PM
Mikkel
Guest
Posts: n/a
Congrats. Are you going to have it rolling road measured after the break in period? It could be interesting to know how much torque has improved.
Old 05-15-2004, 01:06 AM
rdane's Avatar
Thanks so much guys! The members here made this one possible. Funny enough it isn't a 3.6 but then again it isn't a 3.0 either Going to take some getting use to as it is pretty easy to spin the tires now on dry pavement in first gear.
After 5 months of being without my wheels...just wanted you guys to see what I would be doing in the morning as the sun comes up!
Back to the original Fuchs now. Once I hit 1500 miles I'll switch to Mobil 1 and then dyno the car on the same machine I used last year. That should be an interesting comparison as I was 182 rwhp and 162 on Torgue or 215hp at the crank with my 3.0. Plan is to dyno the 3.4 as a single plug and then twin plug late summer and see what the difference is.
Old 05-15-2004, 01:43 AM
The color looks like Moca?
I like the look and I'll bet that motor is sweet, wish it was in my ride
Have fun , Dane
Old 05-15-2004, 04:00 AM
Elombard's Avatar
I have been waing for this!!
What did you decide on the wheels? Sold the FIKSES and ??
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-15-2004, 04:10 AM
Licensed User
Shuie's Avatar
I cant believe I missed this.
Congrats Dane! Im glad to see that car back on the road.
Old 05-15-2004, 05:26 AM
ttweed's Avatar
What did your compression ratio end up at? Are you running race gas now with the single plug setup? What ignition are you going with when you twin plug?
Looks very nice. Good job! I bet you're smiling now.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 05-15-2004, 06:35 AM
Senior Member
Superman's Avatar
Awesome, Dane. Can't wait to see it Sunday. I love the engien appearance. I like sleepers, but I also like colorful engines.
I would guess that the 20/21 cams make good use of intake air velocity. the reason I say this is because my engine (still a 3-liter) certainly responded well to the cams with its narrower intake runners (causing air to achieve higher velocity), and now you're getting the same FAT SMOOTH power band with the wider runners, perhaps due to the increased volume, and consequent increased velocity. It's a theory we can discuss Sunday.
There will be at least a couple of winter projects unveiled then. Pretty exciting. Congrats, Dane. Enjoy.
Mocha 1978 911SC. "Coco"
Old 05-15-2004, 06:54 AM
rdane's Avatar
Custom offset, 16" two piece Fuchs, anodized, 8" and 9.5" with 225x45x16 and 245x45x16 SO3s.
Another topic altogether Compression ended up 9.83:1 with a 1mm shim at the cylinder base. So no need for race gas, thank goodness. Motor nearly made Washington smog with zero miles. So while I don't have that issue any longer because of the date of the car I spec'ed the engine so it would smog if ever required.
I will be be doing the Electromotive HPX twin plug set up. Really curious to see what the dyno says with and without race gas in both versions and the result of the twin plugs.
Jim, I took some care to get as much as possible from the CIS. New injectors, lwt Pauter rods, bumping the compression as high as I dared for a street car, the improved CIS/motronic pistons, bored throttle body, and the case/cylinder work. We'll need another group dyno day soon!
You and Paul did an awesome job on his car. Really looking forward to seeing it in the morning.
Old 05-15-2004, 07:07 AM
