DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
AC Switch in Center Console
I am pretty sure the AC switch for fan control (on/off) is toast. Before I break anything, is there a secret for removing it. I don't see a nut or anything else holding it on, it almosts looks like it is a pressure fit.
Words of Wisdom please.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 05-31-2004, 04:59 AM
Remove the console from the floor and then the outer portion. There may be a few screws in the side holding the AC unit in place. Good time to check for cracks. Those using usually crack around the base from your right leg putting pressure on it.
Old 05-31-2004, 05:13 AM
david914's Avatar
You just need to loosen the nut on the front of the switch. You may have to get a little "creative" if you don't have the proper tool to remove it, but a little twisting of the switch housing while using a pair of pliers (or your fingers) on the nut will loosen it up.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 05-31-2004, 06:19 AM
jdowty3's Avatar
Which switch do you mean? The left is the temp control, the middle is the front/rear speaker fade control, the right is the AC evaporator fan switch. The fader is a press fit with 2 locking tab on the top and bottom of the back side. The other 2 have a flat collar style nut under the knob. You can see the nut in the 2nd picture on the right switch with the 2 small holes. I use either an awl or a pair of thin hemostats to remove and install that type of nut.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 05-31-2004, 06:24 AM
scottb's Avatar
Snap ring pliers work nicely on that nut.
1984 Targa
Old 05-31-2004, 07:44 AM
Who is John Galt?
Rondinone's Avatar
The nut has a long slot on each side. You can put a flathead in there and just twist the nut off if it's not too tight.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 05-31-2004, 08:01 AM
DonMo's Avatar
AC Fan switch removal
thanks all, I have it.
DonMo
Columbia, SC
"Go Hokies"
Old 05-31-2004, 09:20 AM
nostatic's Avatar
on a related note, how do you check if the temp control knob is working? Mine has almost no resistance through most of its turn (especially towards the "cold" end), and I'm wondering if one of my AC issues is that the temp control isn't engaging the unit (although I do feel an rpm drop when I switch the evap/fan on).
Old 05-31-2004, 10:24 AM
scottb's Avatar
Todd: The RPM drop is a sure sign that the clutch is engaging. The easiest way to check is to turn the switch off, and observe the a/c clutch, and then turn it on and do the same thing. You should see it turning when the switch is in the on position. Have someone run the temp control up and down. At some point, especially on a more mild day, the clutch should disengage.
1984 Targa
Old 05-31-2004, 10:36 AM
Old thread, I know, but any advice on removing the fader from the housing?
Old 12-07-2012, 07:49 PM
scottb's Avatar
IIRC, my housing cracked when I tried to remove the fader. Our host had a plate that goes over the existing plate. The new plate covers the fader hole, but has the holes for the a/c controls.
HTH.
1984 Targa
Old 12-07-2012, 09:26 PM
Member 911 Anonymous
DRACO A5OG's Avatar
PAG has the full cover too, not sure if it is still available.
'85 Carrera Targa
PCA/POC
Old 12-07-2012, 11:21 PM
Mitch Leland's Avatar
A/C Fan Switch...
I replaced my A/C fan switch w/ Griffith's Variable Fan Switch. It gives you a lot more control for the slower fan speeds.
I also mounted Griffith's compressor cycle light on the A/C panel, plus a fake alarm LED light that one of our members came up with.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 12-08-2012, 11:35 AM
donagain1's Avatar
As per garment's question, the fader control has thin spring steel with "ear" tabs surrounding the plastic switch. Squeezing on them will loosen it enough to manipulate and carefully remove it.
Old 12-09-2012, 10:24 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fader elimenation.
Most of us connect the speaker wires directly to the radio,
and use the radio fader/balance control:
Would this help?
P/N 911.552.259.02
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-09-2012, 10:58 AM
