converting the pcar to run on LPG as well as normal unleaded?
Anyone ever done this? Just curious. ![]() Cheers Jakes:
If you want to run with the big dogs, you can't pee like a puppy!!! 92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!! 81sc / 3.2 litre transplant (Broken BIG Time ) SCWDP deserter - HP junkie wannabe |
No way! it would be an interesting technical project...
I don't know if anyone has done it on a 911.
Andy |
Wow , I love the idea, I myself have thought about , that or Hydrogen
I think I will look in to it more when my current project is down , with a early 80s model 911. Let me know how it goes! Oxfordsearly911@mchsi.com
Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door |
Virginia Rocks!
You could drive it in the HOV lanes here in VA if you do. Might even be eligible for a tax credit. I thought about getting one of those hybrids and taking out the motor to put in a cooler car.
Only problem with that is, nobody knows the long-term maintenance tail on those things yet.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
jakes,
i can't see the point unless you're running 15mpg or lower. great for range rovers etc - but on a sports car!!
Rich ![]() '86 coupe "there you are" |
Better in Person
the city i work for got a few crown vics police cars and had them switched over to LPG. once the cars were switched over the cops hated it. way down on power and up on weight. part of the weight issue was since the were "50" they had to have some type of steel/lead covers for the tanks. gun play you know.
i did drive one (lpg type) of them once (we inspectors used to drive old cop cars) and it was a gutless pig. the gas crown vic police cars go pretty good from my experience driving them. drove em for about 4 years playing undercover, scaring kids and traffic violators.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Information Junky
I've just got to ask; why?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
I think it's an engenius idea!
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Interresting idea but you will need at least a 80 liter LPG tank somewhere in the car next to a smaller normal gas tank. I think it will eat some HP plus it will raise temps even with the newer LPG systems.
87 Carrera Backdate |
my work truck has a switch so i can choose my fuel. i once burned about $45 dollars worth of propane just driving to sacramento from san francisco. i think it was a 1.75 hour drive. on the way home, i switched to gasoline and i burned a quarter tank. big difference. i never refilled the LPG tank since. it took the technician about 25 minutes to fill my truck. not really worth it, besides being greener.
poof! gone |
Information Junky
Wow, Cliff.. .(vash) that is some tough imperical evidence.
I know that the energy per liter of LPG(liquid) is quite a bit lower than gasoline (~75% of gasoline) but $45 dollars worth, for that distance? . ..yikes! Maybe Hank Hill will chime in here.
i Saw a conversion article on one of the motoring programs a while back (I forget which one). They dynoed the car (I think it was a BMW) before & aftewr the conversion and also tested the MPG. The power went up by about 5~10hp IIRC and the MPG went down by a few miles.
My only concern would be if the government decided to stop the tax break at the review date and it became just as expensive as petrol. My local Shell station is now up to 85p ($1.55) per litre.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Fuchs w h o r e
The biggest problem to overcome if you want to switch a 911 to propane is where do you put the tank? I don't think you can put it in the front luggage compartment because if the tank leaks the compartment will fill up with propane gas, not allowing it to dissipate. Another problem is icing. Propane must be heated to turn it from a liquid to a gas. Watercooled cars run the cooling water through a heat exchanger for this. You could do the same with oil, but its not quite as easy as with water. |
no...b/c you already deserted the SCWDP...hmph...
83 SC (gone) // 72 T (gone) |
I always thought the LPG cars lost some power because of slightly reduced efficiency like dvkk said.
I think the problem that I see is that I understand the tanks to be very, VERY heavy, like several hundred pounds. On the other hand, you wouldn't ever have to worry about carbon build up. From what I understand when you pull one of those motors apart the combustion chambers look like the car has never been run.
So it sounds like LPG is really a bust, but what about hydrogen? Besides the obvious problems with a ready supply, what are the pros and cons. I know BMW has been working with it, and even has a refill station somewher in Munich. Also, Arnold Schwarzenegger is said to be converting his H2 to hydrogen and is pushing for more filling stations in CA. If this all comes about, will hydrogen produce performance on par with gasoline? Conversion kits? So many questions...
Rob Black 1983 911 SC Coupe |
I don't really know much about it, but I don't think hydrogen will be something that you can convert, but I'd be interested to hear from some of the more informed.
Ferdinand Magazine
I saw a Camaro in Car and Driver or one those mags many years ago that converted to propane so he could pass Cali emissions with a really radical motor. If that's the case you would want to build a high compression engine to take advantage of the fuel. Of course you couldn't run gas then.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
