1973911s's Avatar
Question about lowering front end
I have lowered the front end, I took it to the point that the 11mm nut came really loose, and can't get the car as low as I like.
Is it possiable that I can back the screw out to far?
Any other ideas to lower the front?
Michael
1984 Carrera Targa Sold to fellow Pelican
1973 911S Targa - Sold to fellow Pelican.
Old 06-19-2004, 08:09 PM
Metal Guru
911nut's Avatar
Take the adjusting screw completely out. Pull off the adjusting arm and re-index it with the arm toward the floor. Put the screw back in and set the screw so that 10 threads are showing out the top of the arm. If you have stock torsion bars that should get you close.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 06-19-2004, 08:34 PM
