3.2 Upper Engine Rebuild Questions
On a 3.2 with 101,000 miles using one quart Valvoline 20/50
every 800 miles or so, smoking on deacceleration just starting
to need a valve guide job. Is there a difference in valve guides ?
and what is the opinion in doing new rings while you are there ?
Any things else that I need to check while the heads are off ?
What about new valves ? the heads are getting redone.
I only have so much money to play with, it is either put it all
in the engine or.... just do what is necessary and go with
exhaust, chip. This is a bone stock 89. The exhaust I am looking
at with a chip would be $2,000.00( Fabspeed,SSI's), The base upper rebuild is $5,000.00 (Great shop, done right !) It is this or
spend it all on the motor ?
Thanks,
Chuck
Old 06-21-2004, 08:55 PM
Leave the rings alone unless you have a reason to replace them (like breaking them during removal of the jugs).
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-21-2004, 09:21 PM
Friend of Warren
My opinion is that you are a ways off from needing to replace anything. One quart every 800 miles is within specs. I would start thinking about engine work when you get down to one quart every 500 miles or less.
Kurt V
Old 06-22-2004, 06:44 AM
Paul Franssen's Avatar
Without disrespect, I tend to agree with Kurt V.
Something tells me there's a lot of money being spent on Porsches without them needing it, really!
"The ennemy of good is perfect"
Belgik
1988 Carrera 3.2L
Old 06-22-2004, 07:10 AM
This is a case of I have the money NOW, I may not have it in a year or so when the problem gets worse.
Old 06-22-2004, 12:42 PM
bigrubberjeep's Avatar
Well fixing what is not broken is like burning money.
Put it in the bank or buy something that will add value to your car.
Fikse wheels
New interior
Even better yet -another p-car for the track.
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 06-22-2004, 01:12 PM
Bill Verburg's Avatar
Yes, manganese-bronze or phosphor-bronze are preferred
You will need to see whats what upon disassembly. They may be fine or not as w/ the cylinder bores.
Any things else that I need to check while the heads are off ? What about new valves ?
You need to seriously think about budget and goals. If revs will be increased you need to go to the crank and do the rod bolts, If increased non stock performance is desired then valves, cams, exhaust and engine management will be needed.
It's tough to do this stuff incrementally.
Bill Verburg
Old 06-22-2004, 03:16 PM
